Author Topic: Does the Keycool 87 keyboard have standard sized keys?  (Read 1843 times)
Offline Moralless
« on: Thu, 21 August 2014, 08:26:04 »
Hello so I bought the Keycool 87 w/ Cherry MX clear switches(the blank spacebar version) from here: http://www.aliexpress.com/item/keycool-84-mini-mid-87-mechanical-keyboard-in-stock-cherry-MX-CLEAR-Switch-compact-size-white/1472391288.html, and I was wondering if this had standard keycap sizes. I tried searching for the answer online but only found info on what the actual standard size keycaps are and I am unable to determine if the Keycool does have standard sizes from the images.
Offline margo baggins
  • Dungeon Dweller
  • Get back to work!
Re: Does the Keycool 87 keyboard have standard sized keys?
« Reply #1 on: Thu, 21 August 2014, 08:41:23 »
My keycool had standard size caps but a funny space bar. i'm fairly sure I read that they revised the board and bought out a version that didn't have a funny space bar, but I don't know if that's 100% right. All the other caps are standard.
I got boards.
« Reply #2 on: Thu, 21 August 2014, 08:45:20 »
Mine has standard size keys and a normal spacebar. And Cherry brand switches.
The new ones have Kailh switches, and I think they stuck with the standard key sizes including the spacebar stems.
  • Dungeon Dweller
  • Get back to work!
« Reply #3 on: Thu, 21 August 2014, 08:46:00 »
I thought that was teh case - mine was way old, first mech I bought years ago.
I got boards.
Offline Moralless
« Reply #4 on: Thu, 21 August 2014, 08:58:31 »
Thanks for clearing that up, I read your review (which made me buy it btw :P) but it didn't have any info on the keycap sizes.
« Reply #5 on: Fri, 22 August 2014, 20:01:32 »
Mine also standard size, and Cherry switches.
Jade's review is here.
My space bar comparison pictures (between QFR and KeyCool) are in his thread here.
