Author Topic: Making my PCB hot swappable.  (Read 15218 times)
Offline Moralless
« on: Thu, 21 August 2014, 20:00:57 »
I found this link from a reddit post showing the plug in inserts to make a PCB hot swappable: http://au.mouser.com/new/harwin/harwinpcbsockets/. But I'm not sure if it will work with the cherry mx pins (not the pins that come with the PCB mounted switches).
Since referring to this: http://www.cherrycorp.com/english/switches/key/mx.htm it says the diameter of the pins are about 0.059 inches +- 0.002. And looking at this pdf file: http://www.mouser.com/catalog/catalogusd/647/1848.pdf which shows the dimensions of the different input sockets, it seems like the only option that would suit the cherry mx pins is 575-036400 (figure R) which has a pin diameter range of .048-.064 inches.
Now, I have no experience with these sorts of parts and was wondering if this range is too big to be able to reliably hot swap cherry mx switches that are plate mounted? And also the same question for LEDs which have a diameter 0.039 +- 0.004 inches with part #:575-033100 (figure K).
Offline qwack
Re: Making my PCB hot swappable.
« Reply #1 on: Fri, 22 August 2014, 04:38:18 »
I've made a few experiments with hot-swappable switches, and the measurements given by Cherry are for the holes in the PCB, not the pins. The pins are .035-39" rather than .059".
Likewise, a typical LED lead is more like around .020-25" in diameter.
Pure Pro w/MX Red - [review]
Offline berserkfan
« Reply #2 on: Sun, 24 August 2014, 15:53:03 »
I eagerly await the results of your experiments.
Offline jackalope
  • Now with 20% more soul.
« Reply #3 on: Tue, 21 October 2014, 04:38:48 »
Very interested.
eh o well
Offline JackMills
« Reply #4 on: Tue, 21 October 2014, 06:11:25 »
Watching this thread.
If qwack has the right measurements your looking at a J or a K. This will be one of those experiments where you can only test it by doing it.
I will be waiting for the results  :p
« Reply #5 on: Tue, 21 October 2014, 06:14:49 »
moralles, feng has an interest check out for a keyboard called the Smart 68. That's the first time I've seen a hot swappable keyboard and I learned a lot in that thread. Perhaps it may help you as well :).
Offline 0100010
  • Not Sure
« Reply #6 on: Tue, 21 October 2014, 10:07:55 »
There is a thread somewhere about a keyboard kind of like this already - where the top plate lifts off the PCB along with the switches // will look for it.
EDIT : Found it // http://geekhack.org/index.php?topic=41004.0
« Last Edit: Tue, 21 October 2014, 10:49:09 by 0100010 »
Offline Eszett
« Reply #7 on: Sat, 23 April 2016, 07:37:59 »
Is it still a secret which Sockets actually fit MX Cherry pins? Or, in other words, which Sockets are used by e.g. the Smart 68? Maybe these Harwin H3183 ?? http://www.mouser.com/ds/2/181/H3183-349245.pdf ??
https://www.harwin.com/products/H3183-01/
Alternatively, the Zhuque keyboard uses some "black units", instead of SIP sockets.Maybe someone can identify them?
« Last Edit: Sat, 23 April 2016, 09:29:32 by Eszett »
Offline japanitrat
« Reply #8 on: Tue, 09 August 2016, 19:51:54 »
Offline MandrewDavis
  • Chasin' That Neon Rainbow
« Reply #9 on: Tue, 09 August 2016, 20:10:30 »
I would also check out what user E3E has done. He seems to be the hotswap expert, Cherry and Alps.
I've come to view humanity as predominantly monkey business.
My Classifieds Thread
Offline japanitrat
« Reply #10 on: Tue, 09 August 2016, 20:21:41 »
Who? (can't find E3E here, or maybe I am just too stupid using the search)
« Reply #11 on: Tue, 09 August 2016, 23:37:15 »
Here is his Alps hotswap buildlog. There is a lot of good info in there and it's much easier for Cherry MX boards as you won't need to drill the PCB.
From Reddit:
Quote from: E3Eves
Switches, yes, but not with SIP sockets; you're going to want these for switches themselves and these for the LEDs. Use a blunt solder tip to push them into the PCB while the iron is heated. This'll be the most hassle-free way of doing it.
Positive over the sockets I see being used on the boards built with it in mind is that these are flush and not lipped sockets. They're push fit and pretty secure. At worst, you might need a dab of glue or epoxy to hold one securely.
I've made four Alps builds using these. It's much easier to do for Cherry MX.
One last little bit I saved.
Hope that helped. In lieu of a hotswap capabilities, I'm content just using Zealios I'm my main board which supports switchtop opening for stem-swaps.
Anyway, I'm sure he would be happy to assist you if you have more questions.
Offline japanitrat
« Reply #12 on: Wed, 10 August 2016, 01:42:26 »
Ah yes, cool, he ia basically referring to the same socket part, afaict. Thanks for linking all these!
