Author Topic: Which Tenkeyless Backlit Cherry MX Brown Board?  (Read 1920 times)
Offline wes1099
  • Technology and Dog Enthusiast
« on: Thu, 21 August 2014, 23:05:00 »
I recently recieved my maxkeyboard 8-switch sampler kit and I decided that I like the browns. I have been looking around and I have looked at all my options, but I have no idea what option would be best. I need backlit, and I need tenkeyless. I don't really care about the backlight color because I can solder in my own if I want to. What would you guys reccomend? The main two things I have been looking at are the Ducky Shine 3 TKL and the CMStorm Quickfire Rapid-i. There is also another CMStorm board just like the Rapid-i except it has front printed keycaps, and I keep going back and forth on weather or not front printed backlit keycaps are a good idea.
[Leopold FC660C]     [GON NeRD 60]    [Infinity Keyboard]    [ Model M Silver Label]
[Topre 45g Silent]     [Gateron Black]    [Cherry MX Black]     [Model Number 1390636]
        [May 20, 1987]
Offline Oobly
Re: Which Tenkeyless Backlit Cherry MX Brown Board?
« Reply #1 on: Fri, 22 August 2014, 03:40:24 »
AFAIK, there is only one backlit CMStorm TKL, the Rapid-i. The Stealth is not backlit.
I would rather get the Ducky, but it's really up to you. Some users have reported problems with the Rapid-i not responding on some boots, unplugging and plugging back in fixes it and the soldering is not up to the standard of the Ducky.
IIRC, the Keycool 87 came with a backlit version, but I don't recommend the latest range since they use Kailh switches, not Cherry MX.
The Ducky Shine 3 TKL is a really solid choice.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline Senthura
  • Your Doom
« Reply #2 on: Fri, 22 August 2014, 04:29:15 »
I got one with blues recently and it's a solid keyboard. 10/10 would recommend. Pick your favorite color lighting or get white and some LED covers to change the color.
Ducky Shine 3 TKL Blue switch & Green backlight
Offline wes1099
« Reply #3 on: Fri, 22 August 2014, 08:15:13 »
Do you know where there might be a Ducky Shine 3 TKL In stock? I know mechanicalkeyboards.com will have them in september.
        [May 20, 1987]
Offline Senthura
  • Your Doom
« Reply #4 on: Fri, 22 August 2014, 22:48:59 »
I got mine from NCIXus.com
