Author Topic: Flex in unicomp casing  (Read 2667 times)
Offline apenney
« on: Thu, 11 June 2009, 18:55:07 »
I just finally got my Unicomp customizer (1 month post ordering it) and I noticed that their quality control has definitely gone downhill.  The unicomp logo bit in the top right is all misaligned and was barely stuck down, and when i press just below the spacebar i noticed the entire casing flexes down a significant amount.
I can't remember this problem with the last keyboard I ordered from them, but that was about 9 years ago now.  Does anyone else's casing feel cheap and flimsy?  I swear it wasn't this plasticey before.
Offline wellington1869
« Reply #1 on: Thu, 11 June 2009, 18:57:46 »
someone else also just mentioned the misaligned logo on a new customizer, in the keyboard review area.
using: ms 7000/Das 3
Offline apenney
« Reply #2 on: Thu, 11 June 2009, 19:06:45 »
Quote from: wellington1869;95581
I'm guessing this is a result of their massive backlog due to being unable to source components, they are rushing things. :(
Offline patrickt
« Reply #3 on: Thu, 11 June 2009, 20:47:24 »
I got mine about two weeks ago. Aside from the logo being painfully ugly, it's fine. I can depress the plastic below the space bar if I press very hard but the case doesn't flex.
Offline huha
« Reply #4 on: Thu, 11 June 2009, 21:00:23 »
No Customizer here, but an Endurapro (August 2008). The case creaks and flexes a bit when pressing the sides, but doesn't flex nor creak below the spacebar.
If I were you, I'd write Unicomp and ask if there's anything you can do to remedy this problem.
-huha
Unicomp Endurapro 105 (blank keycaps, BS) // Cherry G80-3000LSCDE-2 (blues, modded to green MX) // Cherry G80-3000LAMDE-0 (blacks, 2x) // Cherry G80-11900LTMDE-0 (blacks, 2x) // Compaq G80-11801 (browns) // Epson Q203A (Fujitsu Peerless) // IBM Model M2 (BS) // Boscom AS400 Terminal Emulator (OEM\'d Unicomp, BS, 2x) // Dell AT102DW (black Alps) // Mechanical Touch (chinese BS) Acer 6312-KW (Acer mechanics on membrane) // Cherry G84-4100 (ML) // Cherry G80-1000HAD (NKRO, blacks)
« Reply #5 on: Thu, 11 June 2009, 21:03:44 »
Quote from: huha;95598
-huha
same on my endurapro.
