Author Topic: Machine shop ideas?  (Read 3829 times)
Machine shop ideas?
« on: Fri, 22 August 2014, 23:55:44 »
I just discovered that my cousin has pretty much free range in a machine shop in Dallas, Texas with laser cutters, water jet cutters, CNC machines (both for wood and metal), and much more.  They also do a ton of one off designs for local artists.  Photekq should be helping me out with a 60% case design I mocked up but couldn't make in CAD, but is there anything else I should see if they could do?  Even before the GB feng is doing an IC on, I was looking at doing a carbon fiber plate.  Is that something people might be interested in?  They can't laser cut titanium or copper, but they could water jet cut them and they can cut a ton of other things.
Offline Lastpilot
  • Power stance
Re: Machine shop ideas?
« Reply #1 on: Fri, 22 August 2014, 23:59:27 »
Cheaper and lower profile 87u alu cases!
« Reply #2 on: Sat, 23 August 2014, 00:02:00 »
Draw one up in CAD and I'll see what can be made.  He can't anodize at the shop, but he can do it locally or I can in California.
Offline exitfire401
  • The Force is Re/\l
« Reply #3 on: Sat, 23 August 2014, 00:10:11 »
HHKB Alu case. I'd pay close to top dollar for one.
Offline codyeatworld
« Reply #4 on: Sat, 23 August 2014, 00:11:58 »
A brass middle layer for my GONs... :D
Offline Noctane1
« Reply #5 on: Sat, 23 August 2014, 22:00:32 »
Metal ergodox case!
« Reply #6 on: Sat, 23 August 2014, 22:26:29 »
Get me a file for it and I'll see if we can do it.
« Reply #7 on: Sat, 23 August 2014, 22:27:20 »
Lube station? PCB holder?
Offline 0100010
  • Not Sure
« Reply #8 on: Sun, 24 August 2014, 16:44:14 »
Where in Dallas?
Offline AKmalamute
  • HHKB Scrub
« Reply #9 on: Sun, 24 August 2014, 23:34:00 »
I'm still "on vacation" from producing metal Ergodox cases ... but it's a pretty straight forward project and obviously popular; a single sheet of 16-gauge 304 can completely encase one's keyboard. And everyone wants a slightly different combination or thickness ... JD's spacer design totally made that last run I did into a sweet kit. Then somebody suggested a full-hand bottom plate so wrist rests like the Griffiti that MD is running could be snugged into it while still allowing for tenting.
Myself I'm going to be wishing for a low profile phantom case for my upcoming 7-bit plate that should be cut/sent this fall sometime. No idea what that would take but I bet anything generic would sell suitably around here.
HHKB-lite2, Dvorak user
Offline Oobly
« Reply #10 on: Mon, 25 August 2014, 04:20:09 »
If you could machine the slider holes accurately, an aluminium HHKB case would probably sell quite well :)
Not sure that I'd buy a CF plate. Too flexible and could be prone to delamination / breaking in the thin areas between keyswitch holes. I like my plates to be stiff and tough, aluminium is the "softest" I will go, steel is better.
If your 60% case is a nice one, you could probably sell a few of those if you offer them at decent prices. Maybe with brass inserts to tune the weight?
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #11 on: Mon, 25 August 2014, 10:22:13 »
Offline wcass
« Reply #12 on: Thu, 28 August 2014, 15:04:06 »
Do they have a "slip roll"? Custom buckling spring keyboards need laser cut 18 gauge sheet metal and a trip through a slip roll to make the curve.
Offline telegraphist
« Reply #13 on: Wed, 10 September 2014, 13:12:30 »
I agree: more different aluminum cases, including 87U.
I dislike shallow cases though, when caps are fully exposed and sort of "floating" in the air.
Offline admiralvorian
  • DIY
« Reply #14 on: Wed, 10 September 2014, 14:01:45 »
therein lies the point of all this! I love those exposed-switch keyboards!
(I would still probably purchase any style of HHKB case)
Darude Status:
☐ Not Sandstorm
☑ Sandstorm                                               wts wtt wtb
