Author Topic: Quick question  (Read 1620 times)
Offline Iceycold
Quick question
« on: Sun, 24 August 2014, 16:49:08 »
I have a Noppoo Choc Mini and I'd like to swap the red switches to blue switches. Would this be as simple as ordering the switches from a site like mouser and then switching them out like keycaps?
Re: Quick question
« Reply #1 on: Sun, 24 August 2014, 16:53:02 »
no, you have to desolder the reds, and resolder the blues
but switches are easy to source, you can just buy them from MK
Offline Iceycold
Re: Quick question
« Reply #2 on: Sun, 24 August 2014, 17:43:09 »
Alright then. What do you recommend I buy to source them and MK = max keyboards right?
Re: Quick question
« Reply #3 on: Sun, 24 August 2014, 17:45:06 »
