Author Topic: Some negatives with the Das Professional  (Read 6357 times)
Offline phototristan
    • https://www.youtube.com/phototristan
« on: Fri, 12 June 2009, 15:04:52 »
I recently tried out the Das Keyboard Professional for a couple of months and found some negatives with it that I thought I'd share:
-It is a total dust magnet because it has a high gloss finish. This means that it will look dusty most of the time and show fingerprints unless you wipe it with the included microfiber cloth all the time.
-The lettering on the keys started to wear off after only a couple of months. A keyboard of this price should have very sturdy lettering on the keys, not crappy painted on ones that can be rubbed off.
- The keys started to look shiny from wear/usage after only a couple of months. I'm a normal typist, am not that hard on keyboards, but I use them daily.
-This keyboard required two USB ports to be used on my computer via the included USB Y adapter in order for to work correctly and not cause all my other USB devices to drop off.
I'm much happier with my Model M and Customizer 104 in most all respects.
« Last Edit: Fri, 12 June 2009, 15:06:55 by phototristan »
Offline LlamaZorz
« Reply #1 on: Sat, 13 June 2009, 14:22:34 »
I have had a Das III Pro since the day it came out, I pre ordered it.  While yes it may attract dust I have to say so what?  I really could care less about my keyboard being dusty or having finger prints.  As long as it does not hinder functionality then what's the problem.
I type a lot and program a lot and use the Das III for most of the day.  I must say that none of my keys have had there lettering come off, not even close.
Ive never experienced the USB problem you mention, my Das works just like any other USB keyboard across all OS'es with no problems.
You may have had a defective unit, but I still say that this is the best KB I have ever used.
« Reply #2 on: Sat, 13 June 2009, 15:50:33 »
It's obviously a significant problem for a lot of people given that they now include a note card and a USB Y cable in the box explaining that you may have to use 2 USB ports and the Y cable to power it. You lucked out if you do not have to use two USB ports to power yours.
Same thing with the included microfiber cloth, if it getting dusty and showing fingerprints was not an issue, they would not need to include that.
The lettering is not injected into the keycaps (like it is on the Model M for instace),  just cheaply painted on. On a keyboard that expensive, you would think they would do it better. Give it time, your Das Professional will be an Ultimate soon.
Quote from: LlamaZorz;96042
Offline bigpook
« Reply #3 on: Sat, 13 June 2009, 16:05:48 »
I have a das iii and aside from the lettering that is starting to wear off on some keys is holding up excellently.
Offline ch_123
« Reply #4 on: Sat, 13 June 2009, 16:08:10 »
Quote from: bigpook;96073
Anyone else see the irony here? :p
Offline Rajagra
« Reply #5 on: Sat, 13 June 2009, 16:11:40 »
Quote from: phototristan;96071
I do hope my Ultimate won't turn into a Professional. :wink:
My only problem with my DAS is the location of the USB ports, so I don't use them. I wonder if the USB part could be disconnected if unwanted? (I guess not, the keyboard itself probably connects via the internal hub.)
Oh, and I still think the bumps on the home keys are way too small. I've just put a small piece of black electrical tape below the space bar to help me find the home position.
Offline bigpook
« Reply #6 on: Sat, 13 June 2009, 17:06:30 »
I don't use the usb ports on the das III anyways so it isn't a problem. I am not as down on the das as some people here are. My wife does use it and she really likes it. But I think its more the blue cherries then anything else. If the das gives up the ghost I will replace it with a blue cherried filco. The ONLY advantage I can think of immediately is the lettering won't come off of the keys.
Maybe I am being to lenient about that, none of my filcos, HHKB or M's have the lettering going away.
ps: She would probably like the filco alot better too.
Offline ssb
« Reply #7 on: Sat, 13 June 2009, 17:34:16 »
Although I'm not a big fan of Das keyboard, I have to admit that I never had a single problem with any of my das III boards (I own three bought from getdigital). I've connected them on netbooks, various desktop systems and monitor hubs; well, never noticed anything weird, no excessive current use, nothing at all.
The only problem I have is keycaps that showed marks of shining in less than a month. However I cannot consider this a Das specific problem; same happened to my Filco keys in less time.
« Last Edit: Sat, 13 June 2009, 17:38:45 by ssb »
Please excuse my poor English.
Offline bigpook
« Reply #8 on: Sat, 13 June 2009, 17:36:14 »
for awhile there I thought I was the only one blessed with a working das.
Offline ssb
« Reply #9 on: Sat, 13 June 2009, 18:17:36 »
Das usb problems are known, we hear about those all time. I wonder how this never happened to me and a few others.
Dunno maybe a different production bunch.
Offline LlamaZorz
« Reply #10 on: Sat, 13 June 2009, 18:57:23 »
We have two Das Pro's and neither have problems from what I have seen so far in my year of use.  I don't type as fast as many, so maybe our users don't see the problems which may be there.  I dont even use windows and it works great.
On the note of why it comes with the microfiber cloth, well it comes with one to remove the dust which just so happens to aestheticly look bad on that shiny surface.  The Das doesn't somehow attract more dust or get more finger prints on it, due to its material.  It is just more apparent due to its shiny material.  I assure you the IBM M keyboard gets just as much dust and just as many finger prints as the Das.  They simply are not made as apparent.
Offline wellington1869
« Reply #11 on: Sat, 13 June 2009, 21:09:13 »
using: ms 7000/Das 3
« Reply #12 on: Sat, 13 June 2009, 22:07:27 »
Quote from: ripster;96129
Oh, that is hilarious!
I was trying to find something else on that site to amortize the shipping for that key puller but missed that one.
A silicon nubbie.  Now that is Barbie's t....
:) They've got all kinds of fun stuff in that little store ;)
Offline watduzhkstand4
« Reply #13 on: Sat, 13 June 2009, 22:16:06 »
what about the n-key rollover on that?
KEYBOARDS
Cherry Blue *Filco Tenkeyless w/ blank keys* w/ red ESC key thanks to Megarat
Cherry Red Noppoo Choc Mini
IBM Model M 1391401 12/15/88
Siig Minitouch w/ White Alps
SOLD
HHKB Pro 2 white w/ blank keys red ESC key and blank WASD keys
HHKB L-2
Cherry Brown Compaq mx11800
Dell AT101W
Cherry Red Leopold 104-key Otaku FC500RR/ABN
Offline Manyak
« Reply #14 on: Sat, 13 June 2009, 22:34:58 »
I found out the exact technical details as to why the Das keyboard has problems.
Taken from the Deck forums:
USB HID keyboards are strange; there’s no first-in-first-out queing of the data. Instead, there is a “key-down array” Note the “Report order is arbitrary and does not reflect order of events” in the “Comments” column on page 73 of the USB HID specification:
http://www.usb.org/developers/devclass_docs/HID1_11.pdf
Code: [Select]
B down 01000000 04 05 1B Report order is
                         arbitrary and does
                         events
USB polls our keyboard about once every 8 ms. So there is about an 8 ms window in which the ordering will be arbitrary...Then the next limiting factor is the scanning frequency of the keyboard [and we are not planning to change this for our current products].
Deck keyboards actually don't exhibit this same flaw as the Das as far as I know, but even they claim you might see it.
Currently Owned:
Filco FKBN104MC/EB - Model M 1390131 \'86 - Model M 1391401 NIB - Unicomp Endurapro NIB - iRocks KR-6230 - Compaq MX-11800 - Cherry G80-8113HRBUS-2 - Cherry ML-4100 - Cherry MY-8000-something - Dell AT101W (Black) - ABS M1 - Siig Minitouch - Chicony KB-5181 w/ SMK Montereys - Chicony KB-5181 w/ SMK Montereys NIB - Cherry G80-3494LYCUS-2 - Deck Legend
Offline Manyak
« Reply #15 on: Sun, 14 June 2009, 00:09:47 »
Quote from: ripster;96149
Wow, a real design engineer talking to the support guy.  That rarely happens.
Yeah, Deck keyboards are a bit...tacky, but from what I've seen their customer support is excellent. Hell, their warranty even covers modding, and they give you step by step instructions on certain controller mods as well (change USB to PS/2 and vice versa, change LED color, and I think some others as well).
I don't think he was being specific to the Das - why don't the Filco's have this problem?   They're also a USB HID keyboard.
I think the mystery continues.  I liked how they call it "teh(sic) Das problem", bunch of smartasses there too I see.
Also, I was bummed out by this quote from the post:
I was thinking of a Deck with blues, TG3 style without LEDs somehow.
I wish I could tell you, but I have no idea myself. I'm still trying to research a bit on controller techniques used on USB keyboards, but I'm not finding anything I don't already know.
The one thing I hate with the Decks is that damn font and the size and positioning of words on certain keys looks kind of thrown together without much thought (like 'Shift' and 'Enter').
But what would be nice is the ability to manually select which keys are lit up and which aren't - I'd use that all the time gaming. Then keep them off while doing normal work, making it look almost like a blank keyboard.
Currently Owned:
Offline Manyak
« Reply #16 on: Sun, 14 June 2009, 01:11:30 »
Yeah, I saw that keyboard in a couple of places, and it really boggles my mind why Deck asked to get a fugly font on their version.
But hey at least you can always get that board and harvest the switches off of a Scorpius M10 or something.
Currently Owned:
Offline Hak Foo
  • Make America Clicky Again!
« Reply #17 on: Sun, 14 June 2009, 02:07:45 »
I'd sort of love a keyboard with a hub (because I could see it as a sensible spot for a tablet or drive to plug into)-- why does it seem hard to get it right?
500mA from the PC.
100mA to run the keyboard.
Limit each port to 200mA each-- do little 2Gb sticks and mice draw more?  (comparison:  My Logitech MX400 'laser mouse' draws 100mA per the label)
Overton130, Box Pale Blues.
Offline Rajagra
« Reply #18 on: Sun, 14 June 2009, 07:01:32 »
Quote from: Hak Foo;96172
This is one thing I really miss from my dead Logitech G15 (the proper, original version.) One USB port left rear, one right rear. Perfect for a mouse and game controller, or whatever, they really got that aspect spot on.
Offline Hamps
« Reply #19 on: Sun, 14 June 2009, 10:12:59 »
Quote from: ripster
Quote:
Is Deck really planning on releasing a tactile response keyswitch this summer? Because summer is basically here right now. Hopefully they'll be blue, if they're brown I'll be a bit disappointed since I do love a good click. Just let people choose imo!
I am working on this right now but I can't let the cat of out the bag just yet...for now all I can say is that if we do in fact release a new product the first lot won't have blue switches. Check back in June :)
Hey that's me! :)
Yeah, Deck is offering a tactile switch very soon, this month I think, but unfortunately it's not blue.. it's not even brown. It's 'clear'... which is 'white' I think?
I asked them what that feels like since I've only used blues and blacks and they said
They are like the browns but with a slightly higher force. Basically the same as linear but with a soft tactile response.
Offline IBI
« Reply #20 on: Sun, 14 June 2009, 12:52:11 »
Quote from: LlamaZorz;96111
Are you sure? A sponge doesn't attract any more water than a block of metal, but it certainly absorbs more of any water it comes into contact with.
The shiny finish is a downside because whether it not it actually clings onto more finger dirt it does need to be kept clean to look good, and if not it looks worse than other keyboards. It's up to individual buyers to decide whether they think it looks better than a non-glossy finish.
Quote from: ripster;96215
And the look is UNIQUE whether you like it or not.  Too many copycat keyboards around these days.
Unique? It looks like a Logitech Dinovo Edge with a lump stuck on the corner.
Here's a keyboard that does the USB port technically right but aesthetically so wrong.
Actually, I like the large surround look. To me it says missile command/nuclear submarine. It's not a design for anyone after a compact keyboard though.
Quote from: Hamps;96218
Hey that's me! :)
Yeah, 'clears' are actually white, but there are older white switches so I guess whoever named them thought identification trouble was better than confusion with the older model. Qwerters Clinic has pictures of the force graph and slider (I think it uses the spring from the blues): http://park16.wakwak.com/~ex4/kb/tech_cherry_mx.htm
« Last Edit: Sun, 14 June 2009, 18:19:53 by IBI »
Owned: Raptor-Gaming K1 (linear MX)(Broken), IBM Model M UK, Dell AT102W, Left-handed keyboard with Type 1 Simplified Alps.
Offline cchan
« Reply #21 on: Sun, 14 June 2009, 15:20:39 »
Clears are browns with the spring from black. I think. I'm pretty sure.
HP Envy17: Core i7-2760QM, 8GB DDR3, 128GB Crucial m4 + 750GB Hitachi, Windows 7 Home Premium x64, Cherry ML4100, Logitech M500, HP zr22w
IBM Thinkpad X60: Core Duo T2400, 2GB DDR2, 128GB Samsung 830, Xubuntu 12.04 x86, Cherry ML4100, Logitech M205, HP zr22w
Raspberry Pi Model B: BCM2835, 0.25GB DDR2, 8GB Samsung SD card, Raspbian Wheezy, human interaction devices as above
