Author Topic: Hazel's QFR Art and Science  (Read 12640 times)
Offline Hazel
« on: Wed, 27 August 2014, 20:01:41 »
I'm a bit late to the game, but I had an old QFR laying around and I felt creative this weekend.
75761-0
I'm a total noob at this.   As you can see, I wasn't very concerned with the inner surfaces.  The paint process was basic:  Sand, a couple coats of Valspar plastic primer, several coats of Valspar gloss-white lacquer, and a couple coats of Valspar lacquer clear-coat.  I lightly sanded with 800-grit between coats.  I was going for a sheer gloss look, but as you'll see I ended up with something else.
75763-1
After discovering how hard it was to get that rubber off, I ignored earlier tips and went at it with 60-grit.  As a result, I scratched the case up a bit.   But the scratch lines combined with the lacquer paint make it look and feel a bit like painted wood.  I like it.
75765-2
With black keys for maximum contrast.  These are WASD's new UV printed keys.  The texture works well with the paint.
Now we see the magic.  The lacquer paint produced a wonderful texture!
75769-4
Close-up of the texture.
75771-5
And now the science!  Below this new case lurks... a monstrosity.  Last year, I decided I needed Colemak in hardware.  The WASDv2 wasn't out yet.  I did what I had to do.   I am not proud of this work.  (I am, however, happy with the results!)
« Last Edit: Wed, 27 August 2014, 20:06:35 by Hazel »
Re: Hazel's QFR Art and Science
« Reply #1 on: Wed, 27 August 2014, 20:13:51 »
I really like that Colemak hardware mod :D
« Reply #2 on: Wed, 27 August 2014, 22:56:42 »
Very nicely done!
I like the design on the keycaps too - I to XII for the function rows - interesting :)
Offline IndexPlusPlus
« Reply #3 on: Fri, 29 August 2014, 08:52:48 »
Oh, I wish I had problems like that!
