Author Topic: AEK- Orange Alps  (Read 5559 times)
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
AEK- Orange Alps
« on: Thu, 28 August 2014, 13:40:42 »
other than the obvious with the m0116 boards is anyone aware of how to differentiation between between pink and orange alps on m0115 keyboards?
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline intelli78
Re: AEK- Orange Alps
« Reply #1 on: Thu, 28 August 2014, 13:50:58 »
In my experience,
- The difference in color of the stems is quite apparent
- Orange ALPS bind less, you can hit them at an angle and they'll be fine, the pink alps less so
- Orange ALPS are more likely to be found on lower s/n m0115s, ~400,000 and below
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #2 on: Thu, 28 August 2014, 14:21:48 »
In my experience,
that is kind of what i am looking for :thumb:
« Reply #3 on: Thu, 28 August 2014, 14:41:09 »
I would say pretty much the same thing.
Of course, age, dirt, wear, etc, can make a much larger difference.
I put an orange set in a Dell AT101W and it is really nice now.
- Plato
Offline Altis
« Reply #4 on: Fri, 29 August 2014, 22:11:03 »
May I ask where you got the orange set?
I may have mucked up the black alps that came in my AT101...  :eek:
Offline jacobolus
« Reply #5 on: Sat, 30 August 2014, 02:38:03 »
They’re generally pretty similar. The orange switches are older. The sound at bottom out differs a bit, because the orange switches have a tall switchplate, which makes a slightly deeper / less hollow sound. Also, I think the tactile leaves in the orange switches make for a slightly “cleaner” / less complex force curve... some of the pink Alps switches I have have the force varying up and down a bit as you go down (but when typing at speed this isn’t too noticeable I don’t think).
I think some Japanese fans believe there was maybe also some additional factory-applied lubricant in tall-switchplate Alps switches? (I dunno, I haven’t done any kind of chemical analysis or anything.)
The pink/salmon switches are basically the replacement for the orange switches when Alps switched from tall switchplates to short switchplates, circa 1990.
In any case, you’re going to see much greater variety between well vs. poorly maintained switches (e.g. ones that were stored pressed down, or got very dusty/dirty and are now scratchy) than you’ll see between good condition copies of the two types, I think. You might also see some variance from batch to batch or switch to switch within a particular type. Sometime ASAP I need to go do some precise force curve measurements using HaaTa’s force gauge, which will at least provide some rough comparisons.
« Last Edit: Sat, 30 August 2014, 02:41:15 by jacobolus »
« Reply #6 on: Sat, 30 August 2014, 08:29:23 »
They come in Apple Keyboard M0116 and Apple Extended Keyboard M0115 for the lower serial numbers (<400K in the case of M0115).
- Plato
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
« Reply #7 on: Sat, 30 August 2014, 09:19:36 »
Sandy's page that mentions dry lubricant on blue Alps:
http://sandy55.fc2web.com/keyboard/acer_kb101a.html
My photos of amber Alps switches; you can see some sort of substance on the sliders:
http://deskthority.net/wiki/Alps_SKCM_Amber
Bore Awards
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #8 on: Sat, 30 August 2014, 11:25:08 »
i seem to like the m0115 board itself a little more than the 3501 one?
why is it now we do not see many m0115s offered up for sale- just 3501's?
did not know that orange's are more so on sn's under <400k- nice bit of info there :cool:
Offline jacobolus
« Reply #9 on: Sat, 30 August 2014, 11:35:26 »
I think there were a lot more M3501s made than M0115s. Also, they’re newer. The keycaps (and arguably the case) from the M3501 are nicer, but I also prefer orange Alps switches to cream ones.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #10 on: Sat, 30 August 2014, 14:26:34 »
so i found and dug out my m0115.............serial # 485775
and can you believe it- orange alps :eek:
must have been one of those tweeners?
isn't the date code on the back of the front cover? if so i can pop to check the date?
Offline jacobolus
« Reply #11 on: Sat, 30 August 2014, 14:32:31 »
It should be, I think.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #12 on: Sat, 30 August 2014, 16:03:33 »
nothing i could find other than..........1 / 815-1010-1
« Reply #13 on: Sat, 30 August 2014, 19:02:17 »
serial # 485775
I used to say <500K but it is an inexact estimate. I think that my most recent upgrade was from a ~400K serial number to a ~200K. It is also possible that different plants changed over at different times.
The assumption that many more AEK2s were made than AEKs is entirely plausible, but if there were upwards of 1M of the first iteration, how many could there possibly have been in the second?
I thought that this was occurring in the slump time of Apple's popularity.
- Plato
Offline jacobolus
« Reply #14 on: Sat, 30 August 2014, 20:39:47 »
Macintosh sales were about 1 million/year in 1989, and steadily grew up to a peak of 4.5 million/year in 1995, before slumping a bit to about 3 million/year in 1996/1997, and then ramping up again quite a bit especially after about 2001.
So even though this was a “slump”, there were still a lot of Macs (and a lot of AEK IIs) sold during the 1990–1994 timeframe (or whatever). At some point in the mid 1990s they switched to all rubber domes.
« Reply #15 on: Sat, 30 August 2014, 21:16:32 »
I think that Terrapin's pink Alps AEK2 is dated 1989, and I have owned dampened white AEK2s dated 1995, so they were at least somewhat available during those years. I never realized that so many millions of them were out there.
I am surprised that the AEK does not carry a much higher price premium, since it is so much more scarce.
- Plato
