Author Topic: O rings on MX Blues  (Read 3641 times)
Offline halfkiller
O rings on MX Blues
« on: Thu, 28 August 2014, 18:51:38 »
So, I just got my Ducky Shine 2 with MX blues in and thought putting o-rings on it would make it feel great, but it feels like I have to bottom out the keys harder than before(on my old Blackwidow Ultimate) . Does anyone else use o-rings on mx blue? If so did you like them at first ?
Re: O rings on MX Blues
« Reply #1 on: Thu, 28 August 2014, 19:19:11 »
I like O-rings on all other Cherry switches, but prefer landing pads on the blue ones.
- D Trump 2026-10-24
« Reply #2 on: Fri, 29 August 2014, 00:17:01 »
I tried them, but it didn't make as much difference as I'd hoped.
The high-pitched click of the blue switches is, to a lot of people, more annoying than the bottoming out sound.  And you can probably train yourself not to bottom out anyway.
Actually I probably still have a couple of O-rings on certain keys :))  But that keyboard is on my gaming PC, and the opportunities to game these days are few and far between.
Offline Oobly
« Reply #3 on: Fri, 29 August 2014, 02:39:46 »
... it feels like I have to bottom out the keys harder than before...
Could you please explain what you mean by this? You don't have to bottom out the keys at all in order to get them to actuate.
A difference in feel can be the result of different keycaps. Different keycaps have different heights underneath, between the top of the switch case and the cross-braces of the cap when bottomed out. Some keycaps don't even have cross-braces, so you have to use much thicker orings or multiple orings. Cherry profile caps have a very small gap. DCS have no cross-braces.
This is one of the reasons I don't bother with orings any more. I trampoline mod all my switches.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline osi
« Reply #4 on: Fri, 29 August 2014, 08:58:21 »
Used o-rings on my blue keypad at first but I removed them later. It's a personal preference for sho
Offline Neo.X
« Reply #5 on: Fri, 29 August 2014, 09:37:50 »
I only place O-ring on mx blue. It makes the clicky sound more pleasant by eliminating the bottom out sound.
But putting O-ring on other types of switches just makes the feel more mushy.
All those keyboards will be lost in time....
Offline halfkiller
« Reply #6 on: Fri, 29 August 2014, 10:53:07 »
I am a heavy typer and it feels weird to typer on blues with o-rings installed. I will most likely go back to running them without o-rings. Even though it took quite a while to get the orings on all the keys heh. Hm.... I may try it out a bit more before removing them.
Offline halfkiller
« Reply #7 on: Fri, 29 August 2014, 10:53:22 »
Landing pads?
« Reply #8 on: Fri, 29 August 2014, 10:55:31 »
Landing pads?
Some people say that it feels like mush, but after the click, the rest is just waste, anyway.
https://elitekeyboards.com/products.php?sub=access,slpads&pid=sl120_cs
Offline digi
  • elite af tbh
  • keyboard game on fleek
« Reply #9 on: Fri, 29 August 2014, 10:57:39 »
Landing pads?
I'm one of those who think landing pads make it feel like mush..I guess it's personal preference but they're not for me. Don't know till you try it!
Offline halfkiller
« Reply #10 on: Fri, 29 August 2014, 11:52:51 »
Landing pads?
I may have to try that out.  Do they interfere with leds?
« Reply #11 on: Fri, 29 August 2014, 12:30:44 »
Quite possibly. I have never used a lighted keyboard.
Offline halfkiller
« Reply #12 on: Fri, 29 August 2014, 12:45:02 »
MMkay, well they aren't to pricey. I might as well pick some uo.
