Author Topic: Want to make my own Finger Trigger USB Cable  (Read 2250 times)
Offline matrix
« on: Thu, 28 August 2014, 21:03:27 »
Fellow Forum Members,
I'm trying to figure out how to make my own Finger Trigger USB Cable which is shown in the photo below:
As you can see the index finger for the glove has a white button and when it's pressed with the opposing thumb it makes the barcode scanner device execute a barcode scan.
My question is as follows:
What USB wire colors need to be soldered to the button switch  so that the USB cable sends a triggered message to the barcode scanner device to perform a barcode scan?
I'm guessing the data wire in the USB cable is one of the wires that needs to be soldered to the button switch.  Does anyone out there have a guess as to what other color wires need to be soldered to the button switch?   Any opinions welcomed.
« Last Edit: Thu, 28 August 2014, 21:06:20 by matrix »
