Author Topic: Is this IMSTO Thick PBT Tsangan set?  (Read 2253 times)
Offline phoenix1234
« on: Fri, 29 August 2014, 08:03:44 »
I just saw this on imsto website.
75893-0
Do you have any idea about this? Is this IMSTO Thick PBT Tsangan set?
If yes, how can I order it?
Appreciate if anyone can share information about it.
« Last Edit: Fri, 29 August 2014, 08:12:53 by phoenix1234 »
I like linear switches
Offline SirPony
  • EHHHH All Caps Come @ me
Re: Is this IMSTO Thick PBT Tsangan set?
« Reply #1 on: Fri, 29 August 2014, 17:21:44 »
u mean wkl bottom row? tsangan set includes alot more things. U can shoot imsto an email.
Offline esoomenona
  • Gnillort?
« Reply #2 on: Fri, 29 August 2014, 17:25:51 »
A tsangan can include more caps, but it depends on what set you wish to fit on which keyboard. As it stands, his sets already come with a stepped off center caps, so there isn't really anything more necessary at the basic level than a 7 spacebar and 1.5 mods.
I don't believe those are from the same maker as his sets are. The edges are rounded on those caps where his step have sharp edges. They may be intended to do the job, but they don't seem to be a perfect match to me.
Offline phoenix1234
« Reply #3 on: Fri, 29 August 2014, 19:01:37 »
Thank you for sharing information.
Well note that it will need more caps to be a tsangan set.
esoomenona could be right, your highlights on the edges probably answered my question. Perhaps, this doesn't have the same profile with his existing sets. However, I will send imsto an email to have more clarification about this. I will lock to this topic until I have different information about this. Once again, thank you.
« Last Edit: Fri, 29 August 2014, 19:03:29 by phoenix1234 »
