Author Topic: Doubleshot caps compatible with backlight?  (Read 6167 times)
Offline STR8_AN94BALLER
« on: Fri, 29 August 2014, 12:18:33 »
Is there any manufacturer that produces doubleshot keycaps with transparent fill?
This is how my keyboard looks like (I don't know about modifier lengths)
Thanks in advance
Rig | 5820K - 16G 2400 - AMP GTX1080 - 850EVO 1TB - EVGA 750G2 - W7U
P870DM3 GTX1080 SLi - Pending
Offline FrostyToast
  • Litshoard
Re: Doubleshot caps compatible with backlight?
« Reply #1 on: Fri, 29 August 2014, 12:38:54 »
I believe Vortex is making some.
They are also PBT
Quote from: elton5354
Offline IPT
  • Formerly projectD
« Reply #2 on: Fri, 29 August 2014, 12:40:12 »
the GH cherry replica was doubleshot polycarb if i recall correctly
http://geekhack.org/index.php?topic=50292.30
i dunno if polycarb translucent mods made the order list
you can buy the set from tech keys, but white on orange is normal doubleshot and not translucent.
http://techkeys.us/collections/keycap-sets/products/cherry-replica-set
« Reply #3 on: Fri, 29 August 2014, 12:42:58 »
Is there a set which contains fully translucent doubleshot keycap?
Offline IPT
  • Formerly projectD
« Reply #4 on: Fri, 29 August 2014, 13:20:38 »
ducky has ABS shine sets that are translucent.
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=229
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=711
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=710
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=228
spacebar maybe a problem, i dunno if your keyboard uses a universal spacebar spacing
Offline FrostyToast
  • Litshoard
« Reply #5 on: Fri, 29 August 2014, 13:23:05 »
That keyboard does look very strange as well, but I would assume that the spacebar uses the same spacing as every other ANSI keyboard... if all 7 of those mods on the bottom are 1.25x, math says that the spacebar must be 6.25
Offline IPT
  • Formerly projectD
« Reply #6 on: Fri, 29 August 2014, 13:24:38 »
i should clarify, i meant the stabilizer spacing on the spacebar
« Reply #7 on: Fri, 29 August 2014, 14:19:06 »
Only ABS, no pbt?
Offline IPT
  • Formerly projectD
« Reply #8 on: Fri, 29 August 2014, 14:43:14 »
not that im aware of.
backlit caps aren't that common to begin with besides standard OEM ones.
Offline halfkiller
« Reply #9 on: Fri, 29 August 2014, 14:57:14 »
Since my post has next to no replies *sigh* Has anyone used PBT etched caps on a keyboard with backlighting ?  Is the the lettering legible ?
Offline bazh
« Reply #10 on: Fri, 29 August 2014, 14:57:33 »
there are some option for you:
- MaxKeyboard Black Bird
- SP Cherry Replicate set
- some Déck keyboard
- Vortex set
those of Déck and Vortex are PBT, Déck uses their fugly font and Vortex uses Cherry-like one, but with fugly center alignment
HHKB Pro2 white
Newbie again
« Reply #11 on: Fri, 29 August 2014, 16:20:26 »
- Vortex set
no separate keycap available for sale?
Offline IPT
  • Formerly projectD
« Reply #12 on: Fri, 29 August 2014, 17:02:47 »
not really, its etched on the surface, so there's really nothing letting the light through
Offline SirPony
  • EHHHH All Caps Come @ me
« Reply #13 on: Fri, 29 August 2014, 17:22:54 »
the Skidata set from GMK/Cherry is somewhat campatible with backlight
Offline Oobly
« Reply #14 on: Mon, 01 September 2014, 13:28:52 »
Vortex doubleshot PBT with POM legends:
http://geekhack.org/index.php?topic=61149.0
There is an active interest check for them, so join in if you are interested:
http://geekhack.org/index.php?topic=61896.0
Not sure the final quality, but they will be the best backlit keycaps available anytime soon I think. Unless GMK starts to make some doubleshots with POM legends. That would be incredible.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline bazh
« Reply #15 on: Mon, 01 September 2014, 14:31:53 »
- Vortex set
You can find the Cherry replicate set on the classified, and the Vortex set, there's a IC for it now
GMK is only doing ABS so their backlit solution is most likely the same as SP, using PC, in fact they already can do it (technically their windowed keycaps are the double-shot one with PC legend-the window) look at the C keycaps
HHKB Pro2 white
Newbie again
« Reply #16 on: Mon, 01 September 2014, 16:56:42 »
GMK can do clear plastic as the legend, yes. Not tinted clear, just... clear.
The issue is that some colors have a little bleed, such as red, white, and probably a few more. It just depends on which color/profile it it.
I kinda like the way it looks, but I don't have the time to run a GB.
