Author Topic: G80-3000LSCDE (105 key) matrix  (Read 74057 times)
Offline huha
« on: Sat, 13 June 2009, 14:24:54 »
This is the matrix assignment of a G80-3000LSCDE-2 (105 keys, ISO layout). PCB date is 44/08.
This could be used to get it working on a programmable keyboard controller, for deciding whether certain key combinations can be pressed or for sawing off entire parts and adapting the controller PCB.
Pin reference.
Matrix. (Uses the German keyboard layout for reference)
As can be seen, it uses an 8x18 matrix.
-huha
« Last Edit: Sat, 13 June 2009, 14:25:57 by huha »
Unicomp Endurapro 105 (blank keycaps, BS) // Cherry G80-3000LSCDE-2 (blues, modded to green MX) // Cherry G80-3000LAMDE-0 (blacks, 2x) // Cherry G80-11900LTMDE-0 (blacks, 2x) // Compaq G80-11801 (browns) // Epson Q203A (Fujitsu Peerless) // IBM Model M2 (BS) // Boscom AS400 Terminal Emulator (OEM\'d Unicomp, BS, 2x) // Dell AT102DW (black Alps) // Mechanical Touch (chinese BS) Acer 6312-KW (Acer mechanics on membrane) // Cherry G84-4100 (ML) // Cherry G80-1000HAD (NKRO, blacks)
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #1 on: Sat, 13 June 2009, 15:26:38 »
Looks very much like a Model M matrix with Win keys added (so it is the M-like matrix as I suspected). It only grew from 16x8 to 18x8 to have individual columns for LWin and RWin, a bit of a luxury.
