Author Topic: Unitek K151L $40 +shipping, $100 + shipping BIN  (Read 4109 times)
Offline babuinix
i5 3470//GSKILL 8GB RIPJAW X//SEAGATE 1TB//XFX 550W//MSI GTX660 TF OC 2G
Re: Unitek K151L $40 +shipping, $100 + shipping BIN
« Reply #2 on: Fri, 17 October 2014, 12:53:37 »
Yes, there is an AT/XT switch on the bottom, so in AT mode you can plug it into PS/2 or a USB adapter with just a cheap AT to PS/2 passive cable.
Offline babuinix
« Reply #3 on: Fri, 17 October 2014, 13:18:57 »
Thank´s a lot :) I think ill try and buy 2 for $15! Worth it for the caps alone!
« Last Edit: Fri, 17 October 2014, 13:47:58 by babuinix »
« Reply #4 on: Fri, 17 October 2014, 19:39:28 »
If he's got a lot, let me buy one too :p
« Reply #5 on: Fri, 17 October 2014, 19:49:37 »
I'm invoking dibs for letting them know switch type.
« Reply #6 on: Fri, 17 October 2014, 19:53:02 »
babuinix please be our keyboard distributor guy!
You better hope he has 4.
sandy's unitek K151L has MX blacks.
http://sandy55.fc2web.com/keyboard/unitek_k151l.html
You may be thinking of the K159.
Dibs denied!
« Last Edit: Fri, 17 October 2014, 20:00:42 by dorkvader »
« Reply #7 on: Fri, 17 October 2014, 20:03:11 »
:llama:
Offline babuinix
« Reply #8 on: Sat, 18 October 2014, 18:43:23 »
So I ended up doing business with the guy selling the old keyboard, bought the Unitek K151L (black cherry mx) and also a NTC alps white keyboard made in Malaya.
Here´s a sneak peak.
[/url]
Now... were can i get cheap DIN to ps2 connectors? And... how hard it is to convert them to USB NKRO?
« Reply #9 on: Sat, 18 October 2014, 21:27:56 »
[/url]
common on ebay and elsewhere just look. I have a few if you really need.
usb 6kro is available from many commercial products but NKRO is from a soarer converter, which can be about $10 to about $50 to make depending on options.
Offline babuinix
« Reply #10 on: Sun, 19 October 2014, 05:31:03 »
I think ill just buy a converter from ebay then. Any type of brand/format recomended? I know some ps2 to usb converters were better than others...
« Reply #11 on: Sun, 19 October 2014, 11:30:23 »
They are passive. Just cable and connectors. All should perform equally well. I like the ones with a little bit of cable to relieve strain on the jack but either should work.
ps/2 to USB converters use a chip in there which is programmed differently. So some will be better than others. I recommend the ID Innovations ultimode USB adapter. It's $10-$15 but well worth it.
Offline babuinix
« Reply #12 on: Sun, 19 October 2014, 14:02:37 »
Thanks a lot for the informative input! :D
