Author Topic: Closest thing to invaders?  (Read 5177 times)
Offline PortablePlatypus
« on: Mon, 01 September 2014, 01:52:36 »
I'm typing on and old terminal board with black invaders and I love it. What would be the modern equivalent if they're not still making them? Are there any vintage boards that are relatively inexpensive with them? How do the whites compare?
Re: Closest thing to invaders?
« Reply #1 on: Mon, 01 September 2014, 10:17:09 »
Nothing quite compares. Cherries and Alps have "wobble" that cannot be avoided.
Except for that, white or blue Alps are probably closest to black Hi-Teks.
White Hi-Teks are linear and very smooth.
- D Trump 2026-10-24
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
« Reply #2 on: Mon, 01 September 2014, 16:23:03 »
I wonder if that's because space invader switches have two springs each pressing against the slider, and whether that helps keep it straight?
Bore Awards
« Reply #3 on: Mon, 01 September 2014, 16:47:29 »
I think that it is because it is all squat and wide, and instead of a center stem, all 4 corners are stabilized.
Offline False_Dmitry_II
« Reply #4 on: Mon, 01 September 2014, 19:36:23 »
The Whites are linear, so it just depends on if you like that, because of the amazing stability, they are the nicest linear I've used so far. I also think the stability is because of how large the slider is.
Yes, there are relatively inexpensive vintage boards with them, just look for NMB keyboards on ebay. There are generally a few at any given time.
  • RIP
    • Boring twaddle
« Reply #5 on: Tue, 02 September 2014, 02:51:07 »
Be careful though. Before the renumbering, RT101/102/etc was used for both the Space Invader keyboards and the rubber dome keyboards. Later on, the Space Invader ones were renumbered to RT8xxx.
Bore Awards
« Reply #6 on: Tue, 02 September 2014, 22:02:27 »
I think the RT8xxx is more RT8xxxC and it's supposedly the C you look for (and the + means bigass enter). Easiest though is just to ask for pictures of a keycap off, because that way nothing needs to be known about numbering/naming systems.
What terminal board is it?
« Reply #7 on: Wed, 03 September 2014, 02:10:16 »
http://www.ebay.com/itm/261579892602?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
  • RIP
    • Boring twaddle
« Reply #8 on: Wed, 03 September 2014, 02:27:52 »
Space Invaders are the 8000 series. C appears to be clicky, and T tactile. See http://deskthority.net/wiki/NMB_Keyboards
Bore Awards
Offline Altis
« Reply #9 on: Wed, 03 September 2014, 13:19:43 »
I'm only just now discovering space invader switches. From videos on YouTube, they seem to sound exceptionally crisp and clean... no key rattle, just the switch click and rebound.
Yet, there seems to be very little information about them. Might have to pick one up and give it a try.
« Reply #10 on: Wed, 03 September 2014, 14:01:36 »
I'm selling one at http://www.ebay.com/itm/261579892602
Offline Altis
« Reply #11 on: Wed, 03 September 2014, 15:14:53 »
Thanks, but $150 is more than I can afford right now, plus I'm in Canada, so even if you do decide you'd ship to Canada, it'd be north of $200.
This hobby already has me on the ropes at times :rolleyes:
  • RIP
    • Boring twaddle
« Reply #12 on: Wed, 03 September 2014, 15:45:06 »
You should put that on the wiki before it sells!
Bore Awards
Offline ShawnMeg
« Reply #13 on: Wed, 03 September 2014, 16:16:12 »
Agree.  I would like to try out a board and tempted to buy one, but I don't want to get carried away having so many boards and bankrupting myself.
IBM Model F122 X 2 internal Soarer's || IBM Model M122 internal Soarer's || AEK II SKCM Salmon ALPS external adb_usb converter ||  AEK M0115 SKCM Orange ALPS click mod external adb_usb converter || AEK M0115 SKCM Salmon ALPS external adb_usb converter ||
Offline Hypersphere
« Reply #14 on: Wed, 03 September 2014, 16:19:34 »
These switches are also stable with respect to off-center hits. For example, large enter keys with these switches don't bind the way some switches do when struck off-center.
Offline Altis
« Reply #15 on: Wed, 03 September 2014, 21:51:26 »
Story of my life right now. So many things to buy, so little money...  :rolleyes:
I'm still amazed at how much this hobby can cost.
Based on the few vids I've seen of space invader NMB keyboards, these things sound like they are tight as a drum. I wonder how heavy they are.
Offline jacobolus
« Reply #16 on: Thu, 04 September 2014, 16:08:51 »
Clicky SMK switches (e.g. the clicky “monterey” blue Alps-mount type, or the clicky Cherry-MX–mount type) are somewhat similar in feel to clicky space invaders, IMO. A bit more travel distance though. SMK switches are also out of production, but much easier to find keycaps if you use the MX- or Alps-mount types
« Reply #17 on: Thu, 04 September 2014, 16:57:40 »
Good question.
They feel great but are probably on the heavy side.
Offline jacobolus
« Reply #18 on: Thu, 04 September 2014, 17:12:54 »
Really? The clicky space invader board I tried had very light action, similar to blue MXs or “monterey” blue SMKs.
Offline Hypersphere
« Reply #19 on: Thu, 04 September 2014, 17:15:47 »
Time for quantitative keyboard science! Break out the ripometer! Stack those nickels on the keys and record how many it takes to actuate. :)
Offline paicrai
  • mindblank
« Reply #20 on: Thu, 04 September 2014, 18:04:10 »
americans. OH YOU MEAN-
THE FEMINIST ILLUMINATI
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #21 on: Thu, 04 September 2014, 18:42:01 »
good comparison................
my clicky SMK's are probably just a bit heavier than my black space invaders, however your assessment with them being close to blue monterey's is all over it and pretty close on my end :cool:
i have a leading edge and a laser with clicky SMK's-- actually i am quite fond of the switch even though they wobble a bit :eek:
of course that is only my feeble opinion :-\
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
« Reply #22 on: Fri, 12 September 2014, 01:59:56 »
I am glad to see how well liked they are from basically everyone who has used them before. It seems a somewhat small group.
Agreed, along the label pic or just the info from it. Possibly also shots of the insides as well. This is only the second space invader in that format I've seen, the first being the one fohat used to get his blacks for the ansi apple thing.
« Reply #23 on: Fri, 12 September 2014, 02:31:34 »
Where exactly would I put it on the Wiki? I'll throw up the general label info and a couple of pics but I'm not going to open it up.
  • RIP
    • Boring twaddle
« Reply #24 on: Fri, 12 September 2014, 02:40:10 »
Always a photograph — prevents typos, and ensures that people cannot doubt the veracity of what's written in the text.
Use this page as an example, and create something similar for yours:
http://deskthority.net/wiki/Cherry_G80-1000
(There are no pages yet on NMB Hi-Tek keyboards at all. Not one.)
This might help:
http://deskthority.net/wiki/Help:Creating_pages
http://deskthority.net/wiki/Help:Uploading_images
(Those pages probably need improvement, but at least we have something!)
Bore Awards
Offline ShawnMeg
« Reply #25 on: Sat, 13 September 2014, 19:14:37 »
delete post.
« Last Edit: Sat, 13 June 2015, 18:28:04 by ShawnMeg »
