Author Topic: Razer blackwidow T.E  (Read 1261 times)
Offline Dr.Chipotle
« on: Mon, 01 September 2014, 16:04:01 »
Hey anyone knwo how to add leds to a razer blackwidow T.E i thought i would do a fun project and wanted to know
Re: Razer blackwidow T.E
« Reply #1 on: Mon, 01 September 2014, 19:02:38 »
Doesn't have PCB  support. You can either handwire through the plate, or just use EL-wire.
Offline frosty
  • jukebox hero
« Reply #2 on: Mon, 01 September 2014, 22:22:16 »
like what TacticalStache said, you can't. the only holes for leds are on the caps lock, scroll lock, F9, F10 and the logo. even if their are holes for leds, there is no place for solder resistors on. and even so, no pcb support. just go get a ducky or kustom if you like backlight lol :p
