Author Topic: Can microtron keyboard be remapped  (Read 3829 times)
Offline argcargv
  • tempting the banhammer
« on: Mon, 01 September 2014, 20:58:16 »
Hi, is anyone familiar with microtron?
Do you know if this keyboard can be remapped?
http://www.personal-media.co.jp/retail/utronkb/info.html
I see in their pdf manual that there is a english layout, but could not find the qwerty version.
I could only see the tron version layout
thanks!
Offline FrostyToast
  • Litshoard
Re: Can microtron keyboard be remapped
« Reply #1 on: Mon, 01 September 2014, 21:10:12 »
For that price, I would get an ErgoDox if you haven't already purchased that. Doxes are programmable for sure! Plus they are so much more ergonomic than that.
Quote from: elton5354
Offline jacobolus
« Reply #2 on: Mon, 01 September 2014, 21:15:37 »
Plus [ergodoxen] are so much more ergonomic than that.
I really can’t agree with that. The μTron is a much more carefully designed and much more solidly built keyboard than the Ergodox, and which one is “more ergonomic” depends a lot on the typist. I think each has some advantages and disadvantages from an “ergonomics” perspective.
The Ergodox has the advantage of being a great community project, fully programmable, and something that people can take pride in building themselves. But there are IMO some real problems with the design.
The main problem I have with the μTron is that it’s designed for Japanese people with tiny hands. My average-American-male size hands are a bit too big.
Anyway, to answer the OP: I don’t think it’s especially programmable, but you could always replace or augment the controller with your own Teensy or whatever.
« Last Edit: Mon, 01 September 2014, 21:17:52 by jacobolus »
Offline argcargv
« Reply #3 on: Mon, 01 September 2014, 22:05:47 »
Yep, already have an ergodox, using Hasu's tmk firmware on that and it is magnificent  :thumb:
Just want to try something else, besides it is the almighty topre
Offline argcargv
« Reply #4 on: Mon, 01 September 2014, 22:06:48 »
hmm... should I use this board as my first teensy mod?  :eek:
« Reply #5 on: Thu, 04 September 2014, 15:38:09 »
I'm pretty sure you can put the utron in "TRON" layout, which is based on dvorak, both otherwise it's not very programmable.
I think hasu has a beta part of TMK_firmware that can act as a USB-to-USB adapter. Then you can use it to reprogram the utron however you want, like the qido does from qwerty to dvorak, only programmable. Like the saorer PS/2 to USB only with USB on both ends. I've never tried it, but it could work.
