Author Topic: Can anyone ID this Cherry POS board?  (Read 2876 times)
Offline 1391406
« on: Thu, 04 September 2014, 19:49:34 »
The reviewer never mentioned which board this is nor responded to an inquiry by another viewer.
Re: Can anyone ID this Cherry POS board?
« Reply #1 on: Thu, 04 September 2014, 19:52:11 »
Offline 1391406
« Reply #2 on: Thu, 04 September 2014, 23:26:17 »
I think it's a G80-3190HDU, though the MX8200 pointed me in the right direction and is roughly the same.
« Reply #3 on: Thu, 04 September 2014, 23:32:24 »
you are correct, though it was hard to see if it's doubleshot or lasered with that shaky cam.
That is the winkeyless predecessor to the G80-8200, should have clears and NKRO diodes. I had the chance to proxy one for someone once and prefer it to the G80-8200.
Offline berserkfan
« Reply #4 on: Sat, 06 September 2014, 08:02:06 »
Its a 3190. I have one exactly like it. Not worth buying you cannot program it without windows XP
« Reply #5 on: Sat, 06 September 2014, 08:11:47 »
Just because you can't program it doesn't mean it's not worth buying for the right price.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #6 on: Sat, 06 September 2014, 10:25:50 »
I had a 3190 once. That board is cool for 2 things. First, the numpad has row E profile so you can use them on the numrow for super clean look (well you will need to find a 1u 0 key somewhere else like a 1950). Second it's one of the few models you could get a fulltouch black on beige caps lock.
It is a nice board if you don't mind the slightly odd layout and having a magstripe. It is a serious pita to program, but once you set it back to normal (or if you get one NIB it shouldn't even be a concern as it would have standard to match the legends by default) you never have to muck around with the awful dos style programmer again.
