Author Topic: Need Winkeyless Keycap Set for Custom Phantom  (Read 3955 times)
Offline DrHubblePhD
  • I am star stuff
« on: Fri, 05 September 2014, 14:54:14 »
Hey I just bought a custom phantom that came in a black filco case, I need a set of keycaps that 1) accommodates the winkeyless format 2) is pbt or doubleshot abs 3) something that is not a bright color, wither black, white or gray would be ideal!
Offline FrostyToast
  • Litshoard
Re: Need Winkeyless Keycap Set for Custom Phantom
« Reply #1 on: Fri, 05 September 2014, 15:07:02 »
So what you need is a normal base keyset along with a tsangan set that is provided. A tsangan set will have everything you need to fill a wkl board.
Most GBs have a tsangan set if you pony up a little more cash
Quote from: elton5354
Offline DrHubblePhD
  • I am star stuff
« Reply #2 on: Fri, 05 September 2014, 18:32:03 »
Could you link me to such a set?
Offline 0100010
  • Not Sure
« Reply #3 on: Fri, 05 September 2014, 19:41:59 »
How about Nuclear Green doubleshot ABS set?  There is a group buy thread on it now, and they have a winkeyless option.
Offline Dreamre
    • kbdlife
« Reply #4 on: Fri, 05 September 2014, 19:58:19 »
Then...your ideal set would be Dolch set!
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #5 on: Fri, 05 September 2014, 21:20:38 »
Can't ever go wrong with classic.
Offline Dreamre
    • kbdlife
« Reply #6 on: Fri, 05 September 2014, 21:24:11 »
How about the right shift though?
What's the difference between HAU and SAU?
« Last Edit: Fri, 05 September 2014, 21:28:07 by Dreamre »
« Reply #7 on: Fri, 05 September 2014, 21:47:01 »
It could use a 1.75 right shift if you wanted to. Otherwise could always get one from elsewhere. H=doubleshot, S=dyesubs.
Offline DrHubblePhD
  • I am star stuff
« Reply #8 on: Sat, 06 September 2014, 08:53:06 »
Where do I obtain such a set?
« Last Edit: Sat, 06 September 2014, 08:57:20 by drhubblephd »
Offline DrHubblePhD
  • I am star stuff
« Reply #9 on: Sat, 06 September 2014, 08:58:57 »
Would that work? It looks like there are some strange things going on.
Offline FrostyToast
  • Litshoard
« Reply #10 on: Sat, 06 September 2014, 09:15:05 »
Looks to have all the mods you need.
Offline DrHubblePhD
  • I am star stuff
« Reply #11 on: Sat, 06 September 2014, 09:57:25 »
What kind of keycaps are they, PBT?
Offline FrostyToast
  • Litshoard
« Reply #12 on: Sat, 06 September 2014, 09:59:59 »
I think it's cherry abs doubleshot so it is still very high quality
If it's not that, then it's PBT or POM.
POM is cool too.
« Last Edit: Sat, 06 September 2014, 10:05:46 by FrostyToast »
Offline Oobly
« Reply #13 on: Mon, 08 September 2014, 03:10:25 »
Those particular ones are doubleshot ABS. Very nice high quality caps. The newer thin lasered PBT caps are a lot worse, IMHO. You'd still have to find a matching right shift from somewhere, though.
If you're willing to take a chance you could pre-order a set of Dolch from Sherry at Originative, but some people have had orders not fulfilled properly from there, so it's an "own risk" kind of thing IMO: http://www.originativeco.com/collections/keysets/products/dolch-pre-order
Or you can wait for Ivan's current GMK Dolch Group Buy to complete (or ask if anyone is willing to transfer a set to you) and see if any sets appear in the Classifieds. It's such a great set.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline Battou62
« Reply #14 on: Mon, 08 September 2014, 07:29:10 »
Did you check the classified? SURELY SOMEONE HAS SOME FOR SALE!
Offline Oobly
« Reply #15 on: Mon, 08 September 2014, 08:49:07 »
The CCnG and Cherry Replicas sets from here will fit: http://geekhack.org/index.php?topic=61632.0
Also, this Granite set: http://geekhack.org/index.php?topic=61819.0
I'm sure you can find more if you dig a little deeper, too.
