Author Topic: Need PBC Pinout For IBM PC AT  (Read 1879 times)
Offline jevvix
« on: Fri, 05 September 2014, 18:44:29 »
I bought an IBM PC AT without the entire cable. Does anyone happen to know the pinout from the PCB? I believe 4 of the the 5 pins on the far right are the ones I need (+, -, data, clock) but I'm not sure which are which. Any help appreciated!
Offline sleepy916
Re: Need PBC Pinout For IBM PC AT
« Reply #1 on: Fri, 05 September 2014, 18:52:05 »
I put some documentation on the pinout in my thread.
http://geekhack.org/index.php?topic=40599.0
Hopefully that helps!
Offline JPG
  • Model F is my new passion!
« Reply #2 on: Fri, 05 September 2014, 18:56:59 »
I put a Soarer on mine recently and still have the paper around ... here it is:
When you look at the pins for the cable, here's what you see (they are the pins on the border of the bcp, look for the missing one as a reference):
Use the "empty" pin as a reference and here's where they go:
Top left is Data
Top middle is Ground
Top right is Clock
Bottom left is Vcc
Bottom right is nothing
Enjoy!
« Last Edit: Fri, 05 September 2014, 18:59:17 by JPG »
Offline E TwentyNine
    • Some of My Keyboards
« Reply #3 on: Fri, 05 September 2014, 19:17:00 »
Offline jevvix
« Reply #4 on: Fri, 05 September 2014, 20:59:51 »
Wow thank you guys for the fast replies. I believe that's exactly the information I need  ;D
Wasn't this one was it?
http://geekhack.org/index.php?topic=62369.0
It was not that one.
