Author Topic: Will getting a mech improve my WPM?  (Read 3930 times)
Offline bdenzer
    • Official-Typing-Test.com
« on: Sun, 07 September 2014, 19:48:52 »
I know that my WPM is quite a bit lower when I use my laptop than my regular desktop keyboard. Will getting a good keyboard improve my actual typing, or just the experience of it?
Test your typing speed at http://Official-Typing-Test.com
Re: Will getting a mech improve my WPM?
« Reply #1 on: Sun, 07 September 2014, 19:52:08 »
I heard you need to spend $400+ in order to break the 200 WPM barrier.
Offline Lingj
« Reply #2 on: Sun, 07 September 2014, 19:53:11 »
Can confirm.
« Reply #3 on: Sun, 07 September 2014, 19:54:12 »
The more you spend on a keyboard, the higher your WPM. Some purchases give step change improvements while some are marginal. Korean kustoms and clacks will give you at least 20+ WPM more per each. That's why sifo is fastest. He has a GON, an LZ-GH, and a few clacks and brobots. Plus he's Korean himself, which helps a lot.
Hope that helps.
Offline bdenzer
« Reply #4 on: Sun, 07 September 2014, 20:01:50 »
Sweet, thanks guys - I only have $250 tho, so I guess I'm screwed... Not Korean either
Offline Lastpilot
  • Power stance
« Reply #5 on: Sun, 07 September 2014, 20:02:32 »
The troll is strong in this thread.
« Last Edit: Sun, 07 September 2014, 20:04:53 by Lastpilot »
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #6 on: Sun, 07 September 2014, 20:02:39 »
I read you had to have high WPM to even qualify to use a mech.
Offline Lingj
« Reply #7 on: Sun, 07 September 2014, 20:03:24 »
I'm dead.  :))
Offline CSCoder4ever
  • If it clicks I dig it
    • my github
« Reply #8 on: Sun, 07 September 2014, 20:04:44 »
Trufax!  :thumb:
Rosewill RK-9100; Poker II; Magicforce 68; Planck; WASDv2 TKL; Corsair k65; minivan; tada68;
*buntu - Debian - OpenBSD
Offline bdenzer
« Reply #9 on: Sun, 07 September 2014, 20:10:00 »
So, a mechanical keyboard is good for nothing except looking cool and annoying people around you... Sounds like a good investment
Offline anowt
  • "I want you to buckle my spring" ♪♪~
« Reply #10 on: Sun, 07 September 2014, 20:11:22 »
low key profile and how quickly the key springs back are two major things to consider when looking for speed. but we're talking very little improvement. my typing speed has increased 15% since i started using mechs (coming from buckling springs). but i can also type way faster on my apple wireless bluetooth keyboard (for the reasons mentioned in the first sentence).
« Last Edit: Sun, 07 September 2014, 20:14:28 by anowt »
Front Line: IBM Model M SSK
Tactical Team: QFR TKL (MX Blue)
Recon: KUL ES-87 (MX Red)
Special Operations: RF 87U 55g
Offline FrostyToast
  • Litshoard
« Reply #11 on: Sun, 07 September 2014, 20:12:05 »
You need to fully deck your keyboard in artisan keycaps in order to type faster.
Much easier to recognize an OG HO Clack than say the letter "A".
Quote from: elton5354
Offline bdenzer
« Reply #12 on: Sun, 07 September 2014, 20:16:01 »
low key profile and how quickly the key springs back are two major details to keep in mind when looking for speed. but we're talking very little improvement. my typing speed has increased 15% since i started using mechs (coming from buckling springs). but i can also type way faster on my apple wireless bluetooth keyboard (for the reasons mentioned in the first sentence).
Thank you... Gotta log off and cry now because the internet bullies were mean to me  :'(
« Reply #13 on: Sun, 07 September 2014, 22:14:22 »
women per minute?
yes
« Reply #14 on: Mon, 08 September 2014, 10:59:27 »
women per minute?
yes
Most things use demik units of measurement :p this is proof.  He's a dawg.
« Reply #15 on: Mon, 08 September 2014, 11:04:32 »
women per minute?
yes
I've heard this is especially true if using an ergodox.
    • my github
« Reply #16 on: Mon, 08 September 2014, 11:05:29 »
women per minute?
yes
I should've brought my poker II to college today  :))
Offline The Mad Professor
  • Ex Scientia, Rabies
« Reply #17 on: Mon, 08 September 2014, 11:20:09 »
women per minute?
yes
The is the only scenario where a low WPM is encouraged. In fact, if your WPM gets higher the 0.005, you need to slow down.
Mad Science means never stopping to ask "What's the worst that could happen?" - Schlock Mercenary
Offline paicrai
  • mindblank
« Reply #18 on: Mon, 08 September 2014, 11:52:47 »
thats up to you dude, the keyboard doesnt do the typing, you do
THE FEMINIST ILLUMINATI
« Reply #19 on: Mon, 08 September 2014, 12:35:44 »
Of course it will.
Just as getting a new set of golf clubs will improve your game.
- D Trump 2026-10-24
Offline Grim Fandango
« Reply #20 on: Mon, 08 September 2014, 13:06:46 »
Normally:
WPM = ((amount spend on keyboard)/2) + 20
For Topre:
WPM = (((amount spend on keyboard)/2) + 20)*1.1
There is a lot of research on the ergodox. But early estimations indicate that when used over a long time, actual WPM could be over 9000. But you have to take that with a grain of salt as it is mostly based on anecdotal evidence from ergodox owners.
Offline FrostyToast
  • Litshoard
« Reply #21 on: Mon, 08 September 2014, 13:51:38 »
Normally:
For Topre:
You missed one of the most important calculations to get WPM.
Once you have your base WPM from the equations above, you must then add the result from the Clackdratic equation: y = ax^2 + bx + c
a represents the total number of artisan caps (inclusive of Bro Caps and Clacks)
b represents the total number of Bro Caps
c represents the total number of Clacks
x represents the amount of money you have spent on your artisan caps
y represents your WPM
You can see from this calculation that as you accumulate more artisan caps, your WPM increases exponentially.
This is extremely dangerous because once you reach even 5 artisan caps, your WPM gets so high that you must deliberately type slower to avoid melting your caps (even your artisans) from the sheer heat generated by your typing.
« Reply #22 on: Mon, 08 September 2014, 15:10:34 »
