Author Topic: hi all!  (Read 1434 times)
Offline Nazedayo
hi all!
« on: Mon, 08 September 2014, 15:58:18 »
Deciding whether to get started with a Leopold FC660M or 660C, either way I think it'll be an awesome ride! =P
Re: hi all!
« Reply #1 on: Mon, 08 September 2014, 17:21:03 »
Welcome to Geekhack!
Either will be a great keyboard :)  Although they are radically different in technologies.
Also consider that the FC660C will be more difficult to find replacement keycaps for, if you decide to customise is a bit down the track.
Offline Hundrakia
Re: hi all!
« Reply #2 on: Mon, 08 September 2014, 19:48:53 »
Welcome!
Re: hi all!
« Reply #3 on: Mon, 22 September 2014, 02:14:38 »
Welcome! M you can find more keysets but not for the spacebar. The C is Topre 45g and thats my favorite switch. Id go for that.   :thumb:
