Author Topic: [IC] There is No Spoon: Reloaded - Inspired by The Matrix...White Rabbit  (Read 6980 times)
Offline 00zeRO
  • mechanicalkeyboards.com
  • * Commercial Vendor
  • The 00verseer of Vault 77
    • Mechanical Keyboards
This next batch will be a single White Rabbit Double Shot keycap. MOQ will be set at 50.
76567-0
Color codes:
Black ABS – NN
White ABS – WFK
What I need from you all is input on the profile. What I think would be good is either Row 1 DCS or Row 2. What do you think?
« Last Edit: Thu, 06 November 2014, 13:39:00 by 00zeRO »
Daily Driver: Typist A w/Midnight Dawn | Kailh BOX Clicks
Junktown 2: Now on eBay!
Re: [IC] There is No Spoon: Reloaded - Inspired by The Matrix...White Rabbit
« Reply #1 on: Mon, 08 September 2014, 21:07:30 »
A single keycap is a bit silly for international members - postage cost would greatly exceed keycap cost.
Offline LechnerDE
« Reply #2 on: Tue, 09 September 2014, 00:39:44 »
Yep, but we are a minority here so it's worth trying for him  :thumb:
Offline 00zeRO
« Reply #3 on: Tue, 09 September 2014, 07:03:53 »
Yes, but you have a voice. How many keycaps would be enough for international to be worth it? Should offer 4 again but at a higher MOQ?
Offline 00zeRO
« Reply #4 on: Wed, 10 September 2014, 15:41:06 »
I just got word that if I do the two pills, one white rabbit, and one glow rabbit from the GB that failed, all in one GB set at 50 MOQ it will be $13 each to start.
I am either going to do just the White Rabbit or combine it with a Glow Rabbit for $3.75 a set.
Which do you think has a better chance?
Offline AKmalamute
  • HHKB Scrub
« Reply #5 on: Wed, 10 September 2014, 16:52:29 »
I'd vote for rabbits (both) but there's a few reasons for that that might apply less to other folks -- ANSI150 keyboard, etc.
Row 2, I think is my vote. But I'll get it regardless of row.
HHKB-lite2, Dvorak user
Offline 00zeRO
« Reply #6 on: Wed, 10 September 2014, 20:08:25 »
What is ANSI150?
Offline LechnerDE
« Reply #7 on: Thu, 11 September 2014, 00:42:04 »
What is ANSI150?
This refers to the size of the CTRL / ALT key. Modern keyboards normally have 1.25 keys while vintage boards often times have 1.50 keys.
Offline 00zeRO
« Reply #8 on: Fri, 12 September 2014, 13:42:27 »
Okay, so I have the numbers for the GB. Please give your input:
If MOQ is set at 100, the White Rabbit 1x1 Row 1 DCS single keycap will be $1.44
If set at 50, then $3.50 each, what say you all?
Offline 00zeRO
« Reply #9 on: Sun, 26 October 2014, 14:32:23 »
After PMK now has a limitation on the amount of votes before an IC can go live as a GB, I have been in talks with Keypop, and well, all the designs that were from the Matrix busted Group Buy on PMK will soon be available through Keypop!
