Author Topic: Macbook  (Read 2257 times)
Offline Smasher816
  • HHKB Master
Macbook
« on: Wed, 10 September 2014, 01:13:44 »
Well I just got a macbook pro 13" for college. It will be nice for stuff on the go, especially with the underlying unix system (I have a few projects running on make+gcc). I tried arch on a laptop before but the battery life what **** and I had all kinds of wifi issues. This seems like the best of both worlds - pretty gui on top, powerful command line below (item2+zsh).
Anyways, I would love to hear any helpful suggestions for someone new to the world of apple. Anything I should really know about? I did notice that the readline shortcuts (C-a, C-e) work everywhere, which is pretty cool - however, getting used to command-a for selecting everything will take a little getting used to.
Ohh and does anyone know how to implement dual role keys? I already opened the keyboard settings and made capslock control. But I want to make it also act as an escape key when tapped (SUPER useful in vim). In linux I would use xcape, but googling "xcape mac" didn't bring up anything helpful.
« Last Edit: Wed, 10 September 2014, 01:16:26 by Smasher816 »
Re: Macbook
« Reply #1 on: Wed, 10 September 2014, 01:20:27 »
If you need to run Linux, or even Windows, but want to keep OS X, have you considered running the other OSs in a virtual machine?  I use VirtualBox.
Offline Oobly
Re: Macbook
« Reply #2 on: Fri, 12 September 2014, 06:28:20 »
I suggest BootCamp and Windows 7 or your favourite Linux flavour. Nice hardware, shame about the OS. And the price.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline Altis
Re: Macbook
« Reply #3 on: Fri, 12 September 2014, 20:44:46 »
I've used Parallels, which runs a virtual machine in a new "space".
It's nice because a four-finger swipe goes between spaces, so you can go between operating systems very fluidly.
Bootcamp is fine if you have no intention of using more than one operating system at a time. I used to do this, but found myself wanting to be able to use both systems at the same time.
