Author Topic: JD45 Keyboard by Carpe Keyboards  (Read 333695 times)
Offline meow a cat
  • Resistance is futile.
Re: JD45 Keyboard by Carpe Keyboards
« Reply #300 on: Sat, 16 May 2015, 05:38:45 »
Any renders of the acrylic spacer? Have you guys decided whether you're going to offer both, or just wood?
Here's a render with a translucent acrylic spacer. The actual spacer may be less translucent than this, more "white".
I have to get quotes on both materials and see if I can offer both.
Thanks for the render, that looks great. I think I would prefer a clear spacer over a white one. If it's white acrylic, I'd most likely pick a wood spacer.
Any guesses on wood type? I'm assuming it's not set in stone until after the quotes.
Boards:
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #301 on: Mon, 18 May 2015, 17:56:11 »
What material is that?
Sorry, I missed that question.  It is 3D-printed plastic.  Shapeways calls it "Strong & Flexible Plastic".  Here it is with a JD45 Prototype keyboard installed.  Unicomp "Model M" for scale.  (Also to show the design inspiration!)  My goal was a very tiny version of the classic IBM Model M case shape.
JD45 Prototype Case Edge View. Samwisekoi 2015.
JD45 Prototype Case Front View. Samwisekoi 2015.
I think I'd like this case a tad taller in back, but it looks and feels good.  The internal support rails work to keep the PCB rigid during typing.  Send me a PM if you want to print or buy one yourself.  It fits a 3.00" x 10.00" PCB, and should fit or be easy to modify to fit the prod boards as well.
Many thanks to GH'er RabRhee and MP at SP for the Retro DSA keycaps I was missing for this build!
 - Ron | samwisekoi
« Last Edit: Mon, 18 May 2015, 18:02:11 by samwisekoi »
« Reply #302 on: Mon, 18 May 2015, 20:03:23 »
Very nice
Offline flabbergast
« Reply #303 on: Wed, 20 May 2015, 04:34:29 »
In case there are some proto PCBs left, I'd take one. I can do SMT soldering myself, as long as the parts are at least 0603, ideally at least 0805.
EDIT: A case as well.
« Last Edit: Wed, 20 May 2015, 04:37:17 by flabbergast »
Offline mylove1431
  • A little bear
« Reply #304 on: Wed, 20 May 2015, 05:08:00 »
really nice ........... :thumb:
 - Ron | samwisekoi
Just A little Bear
Offline nobodyknowsmyname
« Reply #305 on: Tue, 02 June 2015, 14:08:43 »
In for one of the proto PCBs w/ SMD and "affordable" wood case if they are still available.
Offline Tiramisuu
« Reply #306 on: Tue, 02 June 2015, 14:55:41 »
I really need a bigger allowance.
Both the jd40  and jd45  are nice.   A little creativity in cases and these become my favorite boards.
I
Keyboard error F1 to continue.
Poker 2, Gherkin, Lets Split, Planck, Filco
Offline krbuck
« Reply #307 on: Tue, 25 August 2015, 16:44:24 »
This would be perfect for my first custom board. So cool and I'm blown away by JDCarpe's past work. I just want to be sure - we are still waiting for availability?
POK3R - Brown Cherry MX
« Reply #308 on: Tue, 25 August 2015, 16:46:43 »
Just an FYI Jdcarpe is currently away on a cruise and he would probably be the one to answer this question. He should be back in around a week.
Offline krbuck
« Reply #309 on: Tue, 25 August 2015, 17:39:29 »
Ah, ok. I skimmed over this thread a few times; must have missed the status. Sorry for that! Here's a pic of a kitten.
Offline justinyhuang
« Reply #310 on: Tue, 03 November 2015, 10:19:53 »
is everyone busy preparing X'mas? this thread appears to be  a bit too quiet...
just like to appreciate JD's offer on a JD45: this is THE ONLY keyboard that i use at work and home now.
and also to show off my Alder case :p
« Reply #311 on: Tue, 03 November 2015, 10:21:51 »
Oh my, I want that. That case is beautiful.
« Reply #312 on: Tue, 03 November 2015, 10:29:03 »
Very nice work on the case for your prototype!
Any luck on the BT front yet?
Offline jbondeson
« Reply #313 on: Tue, 03 November 2015, 10:30:28 »
I would like to second that. A great way to do the usb cutout as well!
« Reply #314 on: Tue, 03 November 2015, 10:33:29 »
the BT module is on its way and should arrive this week.
i will be experimenting with it when i have all the hardware ready.
« Reply #315 on: Tue, 03 November 2015, 10:37:26 »
thank you both!
yeah i like the case a lot, even more than before i made it.
Alder is the lightest hardwood that i can find in my area and that makes the keyboard super light.
i don't feel a thing when it travel with me everyday in my passenger bag.
« Reply #316 on: Tue, 03 November 2015, 23:16:44 »
the BT module comes late today, i hook up everything and it almost works. ;D
exception being the PD5 used in the scan matrix, when the UART communication is  enabled, is used as the XCLK and a few keys associated to PD5 will not respond...the other keys work with no problem though.
i will have to dig into the atmega32u4 data sheet and see if i can keep PD5 from being used as the XCLK pin.
the last time that i play with micro controllers were more than 10 years ago so this might take me sometime.
at the same time if anyone has experience with UART/USART communication with AVR controllers could shed some light on the way around this it would be very much appreciated.
« Reply #317 on: Thu, 05 November 2015, 12:33:14 »
so i eventually figure out the culprit:
on the PCB, D3 and D5 of the controller were shorted during soldering, so when ever D3 is used, D5 gets messed. =) and D3 happens to be the TX pin for UART.
116267-0
after some desoldering and cleaning up, now my JD45 is happily typing via BT  :) ;) :D ;D
« Reply #318 on: Thu, 05 November 2015, 12:34:55 »
:eek: :eek: :eek: :eek:
« Reply #319 on: Thu, 05 November 2015, 12:54:20 »
This is really a good one,  took me sometime to trace it down. Now that the keyboard is able to talk to the BlueFruit, I will go on to commit the code changes needed later this week.
Offline Wilba
  • Keyboard Stuff Person
    • wilba.tech
« Reply #320 on: Thu, 05 November 2015, 16:17:29 »
:-[ Sorry, my bad.
Glad you got it all working, though!
« Reply #321 on: Thu, 05 November 2015, 16:53:39 »
:-[ Sorry, my bad.
oh no, there is nothing wrong with the PCB, the two pins gets shorted when the controller was soldered.
I don't have the right tool, using a tiny knife could not get the two pins separated, so i just desoldered the chip, clean it a bit, and then soldered it back, and it just works =)
so the PCB is still good  :thumb:
Offline Wilba
    • wilba.tech
« Reply #322 on: Thu, 05 November 2015, 17:08:44 »
:-[ Sorry, my bad.
I was the one who soldered the SMD components... I didn't see that bridge, or I would have fixed it myself.
FWIW most bridges like this can be fixed with copper braid (aka. desoldering wick).
« Reply #323 on: Thu, 05 November 2015, 17:27:56 »
Haha, IC
No problem. It's been a good practice to debug a keyboard that has the potential to be my end game.
BTW where are we in making the JD45 now? Would there be a GB in the near future?
« Reply #324 on: Thu, 05 November 2015, 18:44:52 »
I'm hoping as soon as Bunny Lake can find some breathing room that we can get a GB going for them. He's been a busy man lately.
Offline MikeTheTiger
« Reply #325 on: Thu, 05 November 2015, 21:15:16 »
Cool. I like the layout of this one.
"all the numbers or none of them cmon man" -Kokaloo
Offline Frigid
« Reply #326 on: Thu, 05 November 2015, 21:16:13 »
Looks Nice, happy there is an option for a single spacebar
Offline lootbag
« Reply #327 on: Thu, 05 November 2015, 21:40:16 »
This is good news!
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
« Reply #328 on: Fri, 06 November 2015, 09:44:35 »
I really need to get to building my prototype board now that I have switches. Need to get a hold of all the resistors, LEDs and the controller.
« Reply #329 on: Sun, 08 November 2015, 14:17:51 »
the firmware that would work with Wilba's PCB and talk to BlueFruit via PD3 has been merged to the QMK firmware repo: https://github.com/jackhumbert/qmk_firmware. ;)
« Last Edit: Sun, 08 November 2015, 21:45:39 by justinyhuang »
Offline MrRooks
  • Always be knolling
« Reply #330 on: Tue, 01 December 2015, 15:47:40 »
Just a little something something I printed.  :cool:
Design courtesy of Wilba
Full album:
http://imgur.com/a/QMROF
    • WTB/WTTF Thread
« Reply #331 on: Tue, 01 December 2015, 15:48:58 »
Full album:
That's awesome! How long was the printing time for that?
Offline MrRooks
« Reply #332 on: Tue, 01 December 2015, 15:52:17 »
Full album:
Thanks! I printed it at an unnecessarily high res of 0.1mm per layer(0.35mm nozzle) and it took 20 hours and 15 minutes to complete.
« Reply #333 on: Tue, 01 December 2015, 15:53:21 »
Full album:
That's ****ing sexy as hell. Meowwwww
    • WTB/WTTF Thread
« Reply #334 on: Tue, 01 December 2015, 16:01:17 »
Full album:
Definitely worth it though! It looks great plus there is less polishing to do if any at all.
Offline SL89
« Reply #335 on: Tue, 01 December 2015, 16:07:43 »
Pardon me if I'm late to the party, but the fact that the JD45 is happening means there won't be anymore JD40's right? What ever happened to the SmallFry gb as well?
« Reply #336 on: Tue, 01 December 2015, 16:11:10 »
Actually, there are plans for a redesigned JD40 to be released concurrently with the JD45.
The SmallFry GB is still alive, I hope, and will use the redesign PCBs.
« Reply #337 on: Tue, 01 December 2015, 16:13:37 »
So many things. It's has yet to deliver. :(
Edit: tapatalk is lagging today, so per what jdcarpe said if its using a new untested PCB who knows when it will happen. That buy has ruined 40% boards for me.
« Last Edit: Tue, 01 December 2015, 16:15:19 by SpAmRaY »
« Reply #338 on: Tue, 01 December 2015, 16:19:29 »
Just to assuage your fears, Ray, I can tell you that I have assembled a JD40 using the new PCB, and it works great. Fully backlit, with a Forty kit from Round 5. Using one of my original plates to mount it in a wooden case from Badwrench.
Offline keshley
    • Blog n stuff
« Reply #339 on: Thu, 03 December 2015, 07:19:08 »
I do a little dance in my head when there's new posts in this thread.
HHKB Pro 2       Pok3r
« Reply #340 on: Thu, 03 December 2015, 08:27:28 »
I don't want to reveal too much, but you're going to be doing a lot of head dancing really soon.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #341 on: Thu, 03 December 2015, 08:40:35 »
I'm ready to dance.
Offline keshley
    • Blog n stuff
« Reply #342 on: Thu, 03 December 2015, 08:45:04 »
HHKB Pro 2       Pok3r
« Reply #343 on: Thu, 03 December 2015, 11:45:07 »
May I have the next dance?
« Reply #344 on: Sun, 06 December 2015, 00:22:23 »
Seems like great news is coming soon!
That is exciting.
« Reply #345 on: Wed, 09 December 2015, 20:15:35 »
Just to let everyone know, I know a couple of ICs and mini GBs have popped up for other 40% designs, and that's fine.
BIG THINGS ARE CLOSE AT HAND FOR THIS PROJECT!!
You guys like anodized CNC milled alu cases? Matching plates? Fully assembled keyboards? DIY kits? All this is coming very soon!
How can this be, after a year in development, JD? Did you partner with a highly respected keyboard manufacturer, while keeping the integrity of a custom design?
All will be revealed very soon, my loyal followers. :D
    • WTB/WTTF Thread
« Reply #346 on: Wed, 09 December 2015, 20:16:34 »
You guys like CNC anodized alu cases? Matching plates? Fully assembled keyboards? DIY kits? All this is coming very soon!
Ahh Yeah!
Offline keshley
    • Blog n stuff
« Reply #347 on: Wed, 09 December 2015, 20:18:00 »
HHKB Pro 2       Pok3r
« Reply #348 on: Wed, 09 December 2015, 20:22:07 »
Okay, so let's say I tried to follow the thread, but, because of its length, got lost. Just an example.
What's the status of this buy? My impression was that it was over and no longer taking orders, right? Just that the current orders have yet to be developed 100%?
    • WTB/WTTF Thread
« Reply #349 on: Wed, 09 December 2015, 20:25:37 »
The "buy" was just a release of a few prototype boards. JD will be doing an actual release of the board soon as can be seen in what he posted above.
