Author Topic: Noppoo choc mini problems  (Read 1114 times)
Offline asgeirtj
« on: Wed, 10 September 2014, 14:50:35 »
So I just bought the Noppoo choc mini and accidentally broke one of the inserts on the spacebar!
Any way to fix this?  If I could clear up the hole i could put my own insert into it but it's completely stuck :/.  I know of this http://www.shapeways.com/model/2510099/blank-spacebar-keycap-5-5x.html?materialId=37 as a last resort
Not a very nice situation :)
Also two other things which i'm curious about
1. All the stabilizers except for the spacebar one are not able to move completely vertical, just thought that was weird!  Makes keycaps a bit harder to install.
2. It seems that the keycaps sit on the switches pretty losely compared to my Filco, if i turn the board over about 8 keys fall off!  I have a BSP set and I understand that in time when you've taken them off and on numerous times they get loose and with the Noppoo it shows, which I don't understand since I thought all switches were supposed to be exactly the same when it is cherry to begin with.
Edit: imgur doesn't work here?  Clicking the pictures works for me at least.
edit2: key just flew off during a gaming session, seems that I need a new set for this keyboard :o
« Last Edit: Wed, 10 September 2014, 15:19:49 by asgeirtj »
Leopold FC900 w/ 67g Purple Zealios - Silver Duck Octagon w/ 62 Purple Zealios
Offline paicrai
  • mindblank
Re: Noppoo choc mini problems
« Reply #1 on: Wed, 10 September 2014, 15:54:19 »
76716-0
THE FEMINIST ILLUMINATI
