Author Topic: wireless keyboard w/ trackpad needed  (Read 2141 times)
« on: Wed, 10 September 2014, 16:06:43 »
Moved my macmini to tv and now need a wireless keyboard with trackpad to use from bed. Any good ones out there? Im eyeing the logitech k400 since the price is cheap but wanted to see if anybody had any experience with it or something similar. Bluetooth or dongle doesnt matter.
Offline pbtforever
Re: wireless keyboard w/ trackpad needed
« Reply #1 on: Wed, 10 September 2014, 16:24:07 »
Apple wireless - great keyoard.
« Reply #2 on: Wed, 10 September 2014, 16:45:05 »
No trackpad playa
Offline irecresum
« Reply #3 on: Wed, 10 September 2014, 23:22:44 »
Well I got the k400r pretty much the same thing and it is great for when you are eating and don't wanna dirty your mech. But it has a short R shift to the right of the up arrow key. Its best features are the mouse button (to control the cursor), F1 button as as 'panic' button to immediately hide ur nefarious activities and show the desktop, and sweet trackpad. It's the no. 1 selling keyboard on amazon for a reason.
Caveat: don't get in the habit of holding in your left hand like I did for hours while surfing geekhack. It'll give u ulnar deviation problems.
Hope that helped
« Last Edit: Wed, 10 September 2014, 23:26:34 by irecresum »
esoomenona: "****, son. Don't you see my ****ing post count? I matter in this *****"
« Reply #4 on: Wed, 10 September 2014, 23:25:33 »
ended up buying it, only 25 bucks so meh. we'll see how it goes.
NOTED!
Offline irecresum
« Reply #5 on: Wed, 10 September 2014, 23:27:16 »
NOTED!
re-NOTED master Demik!
« Reply #6 on: Wed, 10 September 2014, 23:27:56 »
LIES.
no panic mode!!!
but i do have a copy of a picture now!
Offline PointyFox
« Reply #7 on: Wed, 10 September 2014, 23:28:19 »
You can actually somewhat control the trackpad from the back side of the keyboard.  So you may end up controlling the mouse accidentally if you rest the keyboard on your knee or something.
Offline irecresum
« Reply #8 on: Wed, 10 September 2014, 23:33:02 »
LIES.
no panic mode!!!
Please explain. If you need no panic button you can leave ur bbw for all to see but it's usefull as well to just show ur desktop. Hard copy or just the picture?
« Reply #9 on: Wed, 10 September 2014, 23:34:58 »
i pressed f1 (with and without fn) and all it did was select a picture on my desk top (my old avy) and duplicate it.
fn+f11 does the trick tho
Offline irecresum
« Reply #10 on: Wed, 10 September 2014, 23:40:22 »
f1 was a lie yes. correction: press the same button without pressing FN at the same time. How u worked that out pressing a copy of a picture shows u r not as uninformed as previously noted.
but the panic button is there.
"fn+f11 does the trick tho"
mmm nope, but it makes the CCs look like DDs
correction to self: read the f'ing post. Glad u like it! Gotta wipe the trackpad of tissue rebound for seemless function once in a while or it won't work to good.
« Last Edit: Wed, 10 September 2014, 23:53:54 by irecresum »
« Reply #11 on: Wed, 10 September 2014, 23:43:46 »
pressing f1 created a bookmark (had safari open)
looks like fn f11 it is
Offline irecresum
« Reply #12 on: Wed, 10 September 2014, 23:48:37 »
Let's compare when you get mine or yours in your own sweaty palms
but yeah buy it great htpc controller just watch the ulnar deviation - htpc hand
« Reply #13 on: Wed, 10 September 2014, 23:50:53 »
well i dont need it for much tbh. just wanted something to type on for quick stuff.
