Author Topic: ...actually ran into a keyboard savvy vendor at work  (Read 3295 times)
Offline synack
« on: Thu, 11 September 2014, 16:17:00 »
Haven't posted in a long time here but I thought I had to share...
Was cranking away with my RK-9000BR at work while a new vendor was tagging some printers and whatnot.  He stops at my desk, "Cherry browns?"  We then went off comparing to blues versus buckling spring, tenkeyless, otaku...
I've converted quite a few friends over time. This was definitely the first time ever I've met a random stranger that appreciates mech boards.  Nice work distraction...76809-0
Offline paicrai
  • mindblank
Re: ...actually ran into a keyboard savvy vendor at work
« Reply #1 on: Thu, 11 September 2014, 16:23:25 »
nice
THE FEMINIST ILLUMINATI
Offline FrostyToast
  • Litshoard
« Reply #2 on: Thu, 11 September 2014, 16:33:59 »
Did you ask if he was on a forum?
Quote from: elton5354
« Reply #3 on: Thu, 11 September 2014, 17:11:17 »
A guy came into the repair shop and recommended we go to pckeyboard.com for unicomps. I showed him the 1390120 I was using at the time.
« Reply #4 on: Thu, 11 September 2014, 19:19:47 »
hehehe
I'm imagining someone trying to school you on BS boards
Offline synack
« Reply #5 on: Thu, 11 September 2014, 23:48:31 »
I did actually, surprisingly he wasn't on any forum.  Must be a lurker because he definitely was in the know.
Heh, my second computer after the Trash 80 was an IBM XT -- I was hooked early.  ;D  Up until very recently I would swap out Blues for BS every once and a while at work.  We recently moved to a new office building with low cubes and an open floor plan...  To be polite I switched to Browns -- It was also a very good excuse to buy another board.   :cool:
Honestly I've been very pleased with the switch (unintentional pun...)  Browns are definitely work friendly...
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #6 on: Fri, 12 September 2014, 18:09:27 »
The closest I got to this was seeing a guy at work from a distance with white caps on a clearly non-standard board. As I got closer I saw it was a Logitech washable board... Hmpf...
Offline mikekey
« Reply #7 on: Fri, 12 September 2014, 19:04:30 »
A coworker has a Das but did not know the color of the switch.
Offline Razor Lotus
« Reply #8 on: Sat, 13 September 2014, 06:36:56 »
should've asked him which community he was from
