Author Topic: Carbon fiber keyboard case?  (Read 2332 times)
Offline DrHubblePhD
  • I am star stuff
« on: Thu, 11 September 2014, 21:10:13 »
Has anyone attempted to create a custom keyboard case out of carbon fiber using a mold and carbon fiber strips?
Offline FrostyToast
  • Litshoard
Re: Carbon fiber keyboard case?
« Reply #1 on: Thu, 11 September 2014, 21:13:21 »
There is a thread here.
Quote from: elton5354
Offline heedpantsnow
  • Old enough to know better
« Reply #2 on: Thu, 11 September 2014, 21:32:43 »
Hey dude I'm still working on that project, would be happy to answer any questions you have.
I'm back.
Offline DrHubblePhD
  • I am star stuff
« Reply #3 on: Fri, 12 September 2014, 06:28:02 »
I think im going to order some supplies and try it out, ill let you know when I figure out exactly what I want to do. Thanks!
« Reply #4 on: Fri, 12 September 2014, 06:38:32 »
If I had it to do over I would make a female mold of the outside of a thin-walled metal case and a male mold of the inside. Then sandwich all layers at one time. The same way they make CF car hoods (actually quite similar, both have an outside where finish is important and an inside with structure).
I'm back.
Offline Tiramisuu
« Reply #5 on: Fri, 12 September 2014, 14:37:05 »
There are some great videos on making carbon fiber parts with vacuum bagging.    A project of this size is a great way to start and the results can be very production quality.
Keyboard error F1 to continue.
Poker 2, Gherkin, Lets Split, Planck, Filco
