Author Topic: Odd problem with 1391401 and adapters  (Read 15109 times)
Offline genegold
« on: Tue, 16 June 2009, 16:27:27 »
6/23: For current state of the problem, see post #40
While awaiting a blue cube, I got a Radio Shack adapter that worked right off with a used 1391401 that I had picked up on ebay.  Then the cube came, plugged it in and the keyboad Caps Lock and Scroll Lock flashed on and off, which seems to be this keyboard's way of saying, not working (can't start the computer).  So I tried a different USB port and it started right up.  Strange, wonder what caused that?
Today, I shut down the computer, unplug my regular Kensington board from the PS/2 port, plug in the cube and it doesn't work, just the flashing lights. Switch USB ports  - there are 8 - and no go on any of them.  Try the RS one, same deal.  Then I discovered something: If I start up with the Kensington board, shut down, then plug in the cube or the Radio Shack adapter and power up within 10 seconds or so the computer boots fine.  Wait much longer, or try consecutive adapter start ups, no go.
So, what's going on here?
« Last Edit: Tue, 23 June 2009, 08:37:37 by genegold »
Offline wellington1869
« Reply #1 on: Tue, 16 June 2009, 16:43:01 »
weird.  i'd say its a current flow issue but i'm not sure exactly how. But for instance i've had usb drives that worked on the back usb ports but not the front ports and the explanation was that the front ports get less current and the slight difference was enough to cause some usb devices to not work.
Here it sounds almost like once the juice has started flowing on the port, its able to keep going for the (heavy current drawing) model M, but if you cold start it with the M, no go.  I dont know how the current is controlled on the ports, but it almost sounds like a hysteresis issue maybe.
Anyway I'd blame the current draw that the blue cube (as an active controller) is adding, maybe.   Thats my initial superficial guess.
using: ms 7000/Das 3
Offline genegold
« Reply #2 on: Tue, 16 June 2009, 16:43:13 »
Quote from: ripster;96876
Bad cube.  Send it back.
I've given up recommending dongles.  Next time someone asks I'll just tell them to buy a new PC.
Try reading my post again (is it not clear?).  It can't be the cube, or at least the cube alone, since the same pattern occurs with the Radio Shack one.  Though before the cube arrived, the RS one fired right up each time I used it.
Offline genegold
« Reply #3 on: Tue, 16 June 2009, 16:56:39 »
Quote from: wellington1869;96880
weird.  i'd say its a current flow issue..
The Radio Shack one appears to be active, too: http://www.radioshack.com/product/index.jsp?productId=2103747. Both support USB 1.1 and the motherboard manual (a new Gigabyte GA-MA790X-UD4P) says USB 2.0/1.1.  I'll have to try each of these after the computer has been sitting off for awhile.
« Last Edit: Tue, 16 June 2009, 17:01:11 by genegold »
Offline zwmalone
« Reply #4 on: Tue, 16 June 2009, 17:04:58 »
IF I read that correctly the RS adapter worked until you plugged in the blue cube...  I'm wondering if the high power draw of the M (100mA) + power draw of the cube caused some sort of overcurrent that fried your USB controller...
Can't get enough of them ALPS
« Reply #5 on: Tue, 16 June 2009, 17:13:36 »
another thing to try would be to get a powered external usb hub and try it thru that. (assuming the usb controller isnt fried in your computer).
Offline genegold
« Reply #6 on: Tue, 16 June 2009, 17:30:33 »
Quote from: wellington1869;96905
Same thought came to mind, but right now I've got the RS adapter hooked into the same USB port as the cube was last in. Maybe there is some other kind of interaction between the two and the mb.  Could it by any chance be the keyboard's own board?  I've got another kb on the way, but have to make a decision about this one by tomorrow.
By powered hub, do you mean powered off the bus or from the wall plug, presumably with a transformer?  Looking at hubs online, what they mean by "self powered isn't always clearly stated.
Offline genegold
« Reply #7 on: Tue, 16 June 2009, 17:50:00 »
Quote from: ripster;96916
It could be the keyboard.  Controllers are like any other electrical equipment and 20 year old ones do go bad.  That's why I recommend plugging it into another computer.  If the lights start flashing you better send it back.
Is there harm in plugging in one of these hot?  I don't have access to a computer where I can control the power.
« Last Edit: Tue, 16 June 2009, 17:58:03 by genegold »
« Reply #8 on: Tue, 16 June 2009, 18:02:34 »
Quote from: genegold;96915
powered off wall plug with a transformer. that way you can be sure its getting enough current and see if something else is the problem.
Offline genegold
« Reply #9 on: Tue, 16 June 2009, 19:08:35 »
Quote from: ripster;96923
No problem if you're talking about hotplugging a USB port.  Don't hotplug a PS/2 port - your computer lab (library, whatever) won't be happy.
Ideally a PS/2 port computer would be ideal but let's see what happens.
..... the Computer Lab's lights start dimming....
Does the PS/2 port keyboard have to be unplugged?  I'm thinking about somebody not being happy if I or they have to reboot a computer on the PS/2 reattachment.
Offline cchan
« Reply #10 on: Tue, 16 June 2009, 19:54:23 »
On a reattachment you don't need to reboot. At least I don't with an Asus P4B533-VM and windows xp.
HP Envy17: Core i7-2760QM, 8GB DDR3, 128GB Crucial m4 + 750GB Hitachi, Windows 7 Home Premium x64, Cherry ML4100, Logitech M500, HP zr22w
IBM Thinkpad X60: Core Duo T2400, 2GB DDR2, 128GB Samsung 830, Xubuntu 12.04 x86, Cherry ML4100, Logitech M205, HP zr22w
Raspberry Pi Model B: BCM2835, 0.25GB DDR2, 8GB Samsung SD card, Raspbian Wheezy, human interaction devices as above
Offline genegold
« Reply #11 on: Wed, 17 June 2009, 09:02:50 »
I checked it over at a university library with the Radio Shack adapter - there wasn't room for the cube.  Although it didn't like a hot plug in - same port, keys not the same - on restart and cold boot it did work ok (though not quite as quick a response as the Dell keyboard).  That was a slow server system vs. my 1 minute boot, but sufficient to establish that it's probably not the keyboard itself.
« Last Edit: Wed, 17 June 2009, 09:04:52 by genegold »
« Reply #12 on: Wed, 17 June 2009, 09:07:26 »
Quote from: genegold;97002
i still vote for wonky current issues. Have you tried a powered usb hub? If its a current issue basically that combination of adapter/keyboard may just not work on that particular laptop (plugged in directly anyway). On other hand, if all it is is a current supply issue, a powered usb hub may solve it. (Again assuming nothing was fried inside the computer itself).
« Reply #13 on: Wed, 17 June 2009, 09:34:47 »
Quote from: ripster;97009
Welly, you and I may be the two worst guys to be debugging Genegold's problems.  You of course have had Ultranav problems and are going USB.
I was sitting here trying out the Das again and "be-bomp" the USB connection dropped in the middle of a post.  It had been working fine for 15 minutes!!  I had it plugged into my Dell monitor so now have moved it to my Cables-To-Go powered hub to see if it is power related.
We're jinxed!
lol. when in doubt, upgrade! I always say  ;)
I vaguely remember someone complaining about a Das dropping the connex, though maybe its another board i'm thinking of. (Hows that for helpful diagnosis ;) )
Offline genegold
« Reply #14 on: Wed, 17 June 2009, 09:35:47 »
We're jinxed!
I bring good luck.  Cheers!
Have to find a powered hub around my small town today.
Offline genegold
« Reply #15 on: Wed, 17 June 2009, 18:08:04 »
Quote from: wellington1869;97005
Just tried the Belkin wall-powered 4 seater.  Worked at first and seemed to solve the problem.  But just turned off the computer, then tried restart - nothing.  Switched adapters, still nothing.  Unplugged the IBM keyboard from the hub and plugged in Kensington PS/2 - still nothing, first time!  Unplugged the Belkin from the computer's USB port, starts right up.
I keep wondering about the new motherboard and PSU, but what do I know.
Offline wheel83
« Reply #16 on: Wed, 17 June 2009, 18:17:10 »
i bet VIA is behind this somehow!
buy a new cube, or try an adaptor from radio shack or a computer store.
I <3 BS
Offline genegold
« Reply #17 on: Wed, 17 June 2009, 18:23:13 »
Quote from: wheel83;97220
You must have skipped the beginning.  Cube and Radio Shack involved.  But what are thinking re VIA?  This is a two-week old Gigabyte GA-MA790X-UD4P board.
« Last Edit: Wed, 17 June 2009, 18:29:11 by genegold »
« Reply #18 on: Wed, 17 June 2009, 18:39:46 »
you mean the computer wont start? Or do you  mean the keyboard isnt recognized?
if you mean the former, then you're saying with the hub plugged in the computer wont start, but without the hub plugged in, the computer starts?
Have you tried different usb ports on the computer? Is it the same result for the other ports? (It could be just one bum port you have, or a couple of bum ports if they're connected together internally. I did have a laptop once where one of the usb controllers was fried so two ports didnt work right but the other two worked fine).
« Last Edit: Wed, 17 June 2009, 18:46:04 by wellington1869 »
Offline genegold
« Reply #19 on: Wed, 17 June 2009, 19:02:48 »
Quote from: wellington1869;97224
It seems that the original post needs to be replayed:
Add:
- No dead USB ports; it's worked and not worked off the same ports
- The hub worked at first through several startups this afternoon, then the problem this thread is about returned.  Had to unplug the hub to get the computer to start even with a regular modern keyboard.
- Since using the IBM keyboard - intermittently since Friday - I've been losing the PCI parallel card port to the printer.  When the hub was unplugged, the printer started churning pages again. But since I had just unplugged/replugged it, I don't know what the difference was (yet).
« Reply #20 on: Wed, 17 June 2009, 19:18:31 »
if your scrolllock/capslock lights are blinking, can you look up and see if those are diagnostic codes that its blinking?  If they're blinking in a particular pattern they might be a code that you can look up.  (Dell desktops for example work that way with four led's on the back panel). There must be somewhere where you can look up what that blinking means (whether its  a pattern or not), probably on the computer manufacturer's support page.
Its definitely odd that the computer intermittently wont start with the hub plugged in. (have you googled that?).  If you're using a powered hub, then it shouldnt be a power supply issue anymore, I think.
Offline genegold
« Reply #21 on: Wed, 17 June 2009, 19:43:08 »
Quote from: wellington1869;97235
Seems the latter was an occasional problem with Win98, but little then and nothing more.
Found IBM error codes at http://forums.techarena.in/guides-tutorials/1045252.htm, but I assume those require at least a start into bios.  One person reported similar flashing and it turned out to be a bad memory module.  That doesn't make sense here, because the flashing started when the IBM keyboard was first hooked into the PS/2 port, pre adapter.
« Reply #22 on: Wed, 17 June 2009, 19:45:24 »
another question - if you leave the M keyboard out of the equation altogether, and only use the hub and the kensington, through several reboots and etc, does the problem occur?  Or does it ONLY occur shortly after the M has been introduced into the sequence of events?
Offline Rajagra
« Reply #23 on: Wed, 17 June 2009, 22:06:08 »
Quote from: genegold;97231
I'm afraid this isn't 100% clear. "Nothing happens" can mean many things:
  • PC doesn't show any sign of life;
  • Some lights and fans come on but drives don't spin up and there's no video signal;
  • Drives spin up, but no video signal and no actual disk activity;
  • You get no video but lots of disk activity as if the OS is trying to boot;
  • You get video but the OS doesn't try to boot.
You get the idea, these details are needed to diagnose a fault.
Let's get back to basics. Firstly, stop hot-plugging PS/2 connectors if you are doing so. Even the die-hard "I've done it hundreds of times without any problems" people will accept it's not a good thing to do when diagnosing a fault like this.
Next, do a series of tests. (Ideally repeat each stage a few times.)
Start with no keyboards or PS/2-to-USB adapters plugged in at all. Power up. How far does it get?
Power off. Wait 15s. Plug in a PS/2 keyboard straight into the PS/2 keyboard port. Power up. How far does it get?
Power off. Wait 15s. Unplug the keyboard. Plug in a PS/2-to-USB adapter only - no keyboard. Power up. How far does it get?
Power off. Wait 15s. Plug a keyboard into the PS/2-to-USB adapter. Power up. How far does it get?
The sooner you see a problem, the more you've isolated a fault. (There might be more than one.)
One question occurs to me: is the BIOS set up to boot from USB devices?
Offline genegold
« Reply #24 on: Mon, 22 June 2009, 18:13:46 »
Quote from: Rajagra;97264
Second sample of 1391401 keyboard (5/89), same problem.
In Rajagra's 4-step test, it boots all the way until step 4, at which point the Caps Lock and Scroll Locks lights flash and the computer does not power up at all.  That says it's the keyboard - or the keyboard + adapter - but we already knew that.  There is no USB only setting in the BIOS, and it doesn't seem relevant given what I've reported. So, here's a summary of the three scenarios that occur:
- Computer cold with IBM keyboard attached (USB adapter) - computer powers right up
- Computer shut down with IBM attached and then restarted - no power up, only flashing Caps Lock and Scroll Lock lights
- Computer started with other (Kensington) keyboard, shut down, then keyboard switched to IBM and restarted within 5-10 seconds -  powers up - if longer wait, no power up
I thought it might be a capacitor discharge issue, since I wasn't waiting the recommended 45-60 seconds between power ups, but I tried at one-minute intervals for six minutes and still no go.  Two hours, no problem.
Seems like there's some kind of interaction going on between keyboard, USB port and motherboard/PSU.  If the problem was that the keyboard doesn't work with the mb, then the cold boot shouldn't work.  Guess I need an electrical/electronics engineer or a different keyboard.
« Last Edit: Mon, 22 June 2009, 18:17:24 by genegold »
Offline genegold
« Reply #25 on: Mon, 22 June 2009, 19:15:24 »
Quote from: ripster;98447
Or a different computer.
I've got another case in the corner. ;-)
There's got to be something about the motherboard, normal or malfunction, that starts cold but not warm when an clickity kb is attached.
Offline huha
« Reply #26 on: Mon, 22 June 2009, 19:25:06 »
Gigabyte board, eh?
This does sound like some kind of obscure cold boot problem. Current Gigabyte boards are somewhat renowned for having boot problems. You might want to try to contact Gigabyte and ask for advice (update your BIOS etc.)
-huha
Unicomp Endurapro 105 (blank keycaps, BS) // Cherry G80-3000LSCDE-2 (blues, modded to green MX) // Cherry G80-3000LAMDE-0 (blacks, 2x) // Cherry G80-11900LTMDE-0 (blacks, 2x) // Compaq G80-11801 (browns) // Epson Q203A (Fujitsu Peerless) // IBM Model M2 (BS) // Boscom AS400 Terminal Emulator (OEM\'d Unicomp, BS, 2x) // Dell AT102DW (black Alps) // Mechanical Touch (chinese BS) Acer 6312-KW (Acer mechanics on membrane) // Cherry G84-4100 (ML) // Cherry G80-1000HAD (NKRO, blacks)
Offline genegold
« Reply #27 on: Mon, 22 June 2009, 19:31:31 »
Quote from: huha;98454
Gigabyte board, eh?
-huha
Yeah, a new one, maybe worth a return.  BIOS is up to date.  Just emailed Gigabyte.
Offline Rajagra
« Reply #28 on: Mon, 22 June 2009, 21:58:36 »
I think it's a power problem. When you push the power button, the PSU supplies power to some of the power wires but not all. The motherboard needs to return a "power good" signal back to the PSU, which then switches on all the power lines.
I think the IBM is taking too much current and maybe overheating a component. From a stone-cold boot it might be OK because the component doesn't have time to overheat. But if you power off/on the hot component plus the high current draw causes the motherboard to tell the PSU it is not safe to power up.
When you power off and back on within 10s it overrides the "power good" check - this explains why you can change from the Kensington to the IBM if you are quick.
You say you need to wait up to 2 hours to get the system to cold boot with the IBM. Try this: pull the mains lead out and then hold the PC's power button in for 15s. This discharges residual power from the PSU and motherboard. Plug the mains lead back in and try to power up. It should be the same as if you'd waited 2 hours.
I would've expected the powered USB hub to fix all this, but it only helped a bit. And I noticed about the parallel port failing with the USB hub on.
I say assume this is a power problem until proven otherwise. It's amazing how many wierd problems disappear when you put in a quality PSU.
What make PSU is fitted?
Offline genegold
« Reply #29 on: Tue, 23 June 2009, 01:08:03 »
The PSU is a Corsair VX450, considered very conservatively rated and one of the better ones around.
Rajagra, your suggestion seems a good one but didn't work.  However, in the process I found a couple of new scenarios with the IBM keyboard:
- Once the computer is warm, power down and then try restarting within 5-10 seconds, the computer starts up - wait longer and it doesn't (before that only happened by switching keyboards)
- In the latter case (longer wait), switch USB banks and the the computer powers up
(Note: I discovered, at least with this keyboard sample, that flashing lights don't always mean no start; and I ran this test with the Radio Shack adapter - blue cube next time)
What does that tell you?  I can say that it's not a bad USB port per se, because I went back and forth twice (four boots) between the same two on different banks.
In the attached screenshot of the motherboard's layout, the two banks I switched between are labeled USB_1394 and USB_1394_1.  I didn't try the others this time.
« Last Edit: Tue, 23 June 2009, 01:33:23 by genegold »
Offline genegold
« Reply #30 on: Tue, 23 June 2009, 14:25:50 »
I posted this topic on what seems to be the closest thing to an official Gigabyte forum, http://forums.tweaktown.com/f69/.  The resident electric guru posted the following reply:
It sounds to me like the IBM keyboard is either drawing too much current for the adapter and/or the motherboards USB ports. Or through a combination of the above the adapter is sending corrupt Data via the USB Bus.
Without knowing what the max current draw is of the IBM keyboard in question and this article you linked too:- Model M keyboard - Wikipedia, the free encyclopedia states:-
"Sometimes it may be problematic to get them to communicate properly with a modern computer. A PS/2 to USB adapter would be necessary for computers without PS/2 ports, and the AT Model Ms additionally require an AT to PS/2 adapter. Some PS/2 to USB adapters are unreliable because the Model M tends to draw more power than some adapters expect. In response to these complaints, Unicomp added USB models to their lineup."
So as per my comments above, either the adapter is "falling over" due to the high current draw of this keyboard and or it could be exceeding (keyboard and adapter combination or even have a fault) the USB 2.0 current standard of a maximum of 500ma Universal Serial Bus - Wikipedia, the free encyclopedia
Either which way, i am slightly baffled why you wish to use a 20 year old keyboard that has been documentated as being troublesome when used with modern hardware and via an adapter.
Whilst it might be interesting to know what is specifically causing the "fault", the combination of a keyboard that wasn't designed for USB, using an adapter per-se, using an adapter with an adapter unfriendly keyboard makes it more likely that you've actually created a problem, rather than unexpectedly experiencing a fault.
__________________
Try other adapters, or another version in the line of these keyboards?
Offline itlnstln
« Reply #31 on: Tue, 23 June 2009, 14:34:53 »
I love this quote:
It's not troublesome, it's just that your crap can't handle 20 y/o technology.  What is that?
Anyway, what you might want to do is use a powered USB hub as it will have an external power supply to supplement the anemic USB ports on your mobo.  Hopefully, this helps.  I only skimmed your post; did you try just using PS/2 yet?
Offline genegold
« Reply #32 on: Tue, 23 June 2009, 14:39:49 »
Quote from: ripster;98631
I'm baffled why your computer doesn't play nice with the keyboard and two different dongles.  Ours does.
Either:
1) Bad computer
2) Bad keyboard
3) You got 2 Bad dongles (unlikely)
Seriously, you need to do some swapping around of stuff until you isolate the problem.  Get that keyboard to work with someone elses laptop first and then we can help you out more.
Don't listen to Tweaktown gurus that get their info from Wikipedia.
To be fair, in an earlier post by someone who questioned using a 20 year old keyboard, I sent them to Wikipedia.  As much as I don't like or trust the latter, in this case it's the best all-around explanation.
Perhaps Rajagra will have something to add, but I'm suspecting an electrical incompatibility, at least using these two dongles.  Unfortunately, I don't have any laptop available or other way to better isolate it that I know of, except for a PSU replacement.
Offline genegold
« Reply #33 on: Tue, 23 June 2009, 14:49:14 »
Quote from: itlnstln;98632
I love this quote:
No go with a powered (Belkin) USB hub.  I've been assuming that's because the problem is at the USB port bank and the hub can't correct that.  Not sure that explanation is correct, tho.
Offline itlnstln
« Reply #34 on: Tue, 23 June 2009, 15:02:07 »
It sounds like some bad USB ports/controller on the mobo. Have you been able to try it with any other PCs or just straight PS2. I used to use a $4 POS (well, not really) adapter I got from Monoproce.com several years ago, and worked without a problem. I always had it plugged into a powered KVM switch, though. I can't imagine that there is anything wrong with the adapters or the keyboard itself. There is an outside chance that the PSU is bad (or has a bad/underpowered rail), but I would think you would see other problems if that were the case. Do you overclock your PC? I have heard in the past that it can cause some peculiarities with USB.
Offline Rajagra
« Reply #35 on: Tue, 23 June 2009, 18:34:29 »
Quote from: genegold;98501
They are a good make. Rating is not really relevant since you aren't even getting the PC to power up when the problem hits.
This is very strange:
  • You've used a mains-powered hub. That should isolate the PC from any excessive power draw from a keyboard. (Unless there is a bad short, which doesn't seem to be the case.)
  • The PC isn't being confused by "chattering" or other confusion from the keyboard, because it isn't even powered up!
I think this is a motherboard problem, either design fault or failure.
You might be able to confirm this by plugging in a bunch of other USB devices and testing.
The only thing I can think of trying now is a different mains-powered USB hub with more power rating. Seems like a long shot though.
EDIT> Well, two other suggestions. 1: Leave the keyboard in the PS/2 port, or 2: Plug the keyboard into USB after booting and unplug it before shutting down.
Not fixes, but maybe a workaround you can use.
« Last Edit: Tue, 23 June 2009, 18:47:05 by Rajagra »
Offline genegold
« Reply #36 on: Tue, 23 June 2009, 19:49:47 »
itlnstln, I just ordered the Monoprice adapter.  If that doesn't fix it, the mb goes back for replacement.  No overclocking.
Rajagra, I don't quite understand your last suggestion, but I think just changing the USB port to the next bank over is the same amount of effort.
Corsair (PSU) tech also thought it likely the mb and suggested I check for grounding.  I pulled the mb onto cardboard, but for some reason it wouldn't start.  Then I switched cases, something I'd been procrastinating about, but the USB problem was still there.
Thanks to everyone who offered help.  Will report back if and when there's some major change.
« Last Edit: Tue, 23 June 2009, 19:59:07 by genegold »
Offline itlnstln
« Reply #37 on: Wed, 24 June 2009, 08:42:39 »
Quote from: genegold;98694
The mobo needs the screws going into the case for ground; that's why it didn't work on the cardboard.  I wouldn't send the keyboard back, I would try it on a few other PCs first.  I think you have a bad motherboard.
Offline huha
« Reply #38 on: Wed, 24 June 2009, 12:20:19 »
It should also work on cardboard. Screws for grounding are nice to have for a variety or reasons (read: EMI), but they're not terribly neccessary. Ground is usually connected via the ATX plug.
-huha
Offline itlnstln
« Reply #39 on: Wed, 24 June 2009, 12:43:33 »
Quote from: huha;98843
-huha
If this is the case, then there is something definitely wrong with genegold's motherboard.  I would imagine, then, that there is a power handling issue with the mobo causing the USB ports not to function properly.
Offline genegold
« Reply #40 on: Wed, 24 June 2009, 12:51:53 »
Quote from: itlnstln;98854
I am hesitant to draw that conclusion from my cardboard test.  When I first installed this mb and tried starting up a few weeks ago, the cpu and video card fans started to turn, then stopped, spinning freely a few times.  I think that turned out to be the power switch connector needed reversing or something.  Yesterday, at first, there wasn't anything, then the brief fan spin happened a couple of times.  I checked and remade all the connections but couldn't find the problem, which is what led me to switch cases, now that the mb was out.
Offline genegold
« Reply #41 on: Sat, 27 June 2009, 13:54:31 »
The Monoprice PS/2 to USB active adapter came today.  Immediately prior to giving it a whirl, I'd been using the modern (Kensington) keyboard (USB) with a PS/2 adapter into the keyboard port.  Upon plugging in the IBM/Monoprice the computer wouldn't power up, just the flashing kb lights like before.  Then, I switched USB banks and it started right up.  Same old song, except this time it did it without having been plugged in first.  At that moment I'm wondering about the motherboard.  However, ...
As a test, I swtiched back to the Kensington keyboard, this time using its USB connector.  It worked no matter what, whether in the same or different USB ports.  What I draw from that is the difference of electrical load - IBM vs. modern - is the kicker and that the motherboard itself is probably not at fault.  I'll still probably RMA/replace it, just to be sure.  To be continued.
Offline Rajagra
« Reply #42 on: Sat, 27 June 2009, 15:59:24 »
Some motherboards abort power up if they don't detect certain fans spinning. Might have been worth disabling that setting in the BIOS.
Mobos shouldn't need to be grounded by the support posts (indeed some are plastic). But I'm thinking:
  • When the mobo is out of the case you have no case fan connected - the sytem may have realised this;
  • When you draw too much power from the USB ports maybe that is stopping the fans from spinning up fast enough.
  • A poorly designed motherboard might well be dependent on additional grounding via the support posts.
Offline genegold
« Reply #43 on: Sat, 27 June 2009, 16:57:49 »
Quote from: Rajagra;99652
Which setting is that?   manual: http://www.giga-byte.com/Support/Motherboard/Manual_DownloadFile.aspx?FileType=Manual&FileID=19157
XP/SP3.  All the USB ports work, just - looking at them as banks of ports - not necessarily each one at any specific time.  It depends on whether the machine is cold (all work) or has been just shut down, and how long it's been since the latter (<~10 secs ok, >10 seconds have to change USB bank).
Update: A new wrinkle.  I have a master console.  That ~10 sec. figure applies if I turn off the console power to the computer; if left on, then it seems to restart ok on the same port at >10 secs.  I've tried up to 90 secs. so far (Monoprice adapter).
« Last Edit: Sat, 27 June 2009, 17:13:34 by genegold »
Offline Rajagra
« Reply #44 on: Sat, 27 June 2009, 17:23:27 »
Quote from: genegold;99660
Don't worry, it doesn't have the option.
Offline genegold
« Reply #45 on: Tue, 30 June 2009, 12:57:55 »
After the behavior described at the end of my last post, I RMA'd the motherboard for replacement and then hooked up my three year old K8 board (MSI K8NGM2-FID).  The IBM keyboard now works without any problem so far off the PS/2 port(!), as well as, with adapter, the USB ports.  That suggests to me it was either a bad Gigabyte motherboard or poor engineering.  Hopefully, the first.
Offline genegold
« Reply #46 on: Tue, 30 June 2009, 13:13:56 »
Quote from: ripster;100212
Good luck with the new motherboard.
I liked how the Gigabyte forum guy blamed the keyboard.  The Power Supply guy blamed the motherboard.
For a while I even doubted the Blue Cube!!! Still da Winnah!!
A winner.  The Radio Shack and Monoprice work just as well too.
Offline itlnstln
« Reply #47 on: Tue, 30 June 2009, 14:04:07 »
Quote from: ripster;100227
Maybe - nobody has put those through the paces like da Blue Cube. Plus, I'd NEVER trust anything from Radio Shack. I even had a simple phono to submini jack coverter that was bad once. And don't get me started on their electronics...
Blue Cube - why risk anything else for a $6 dongle?
I've put the Monoproce one through its paces.  It's always a go.
Offline itlnstln
« Reply #48 on: Tue, 30 June 2009, 15:55:57 »
Quote from: ripster;100260
Should add to the wiki what worked for you.
Hmm... Will do.  I need to get a copy of that software used in the main article.
Offline huha
« Reply #49 on: Tue, 30 June 2009, 18:17:01 »
Quote from: itlnstln;100268
There's a link in the article pointing you to the place to download the software.
If you're not keen on adding it yourself, just send me the data and I'll add it.
-huha
