Author Topic: Modding Poker 2 with LEDs  (Read 2368 times)
Offline honoka
« on: Fri, 12 September 2014, 15:47:00 »
Hiya people!
I'm awaiting my Poker 2 which should arrive soon. It's the PBT version without the backlight. My plan is to add the LEDs myself.
I've studied the PCB and watched a couple of build logs so the actual work is no problem but I'm unsure of what kind of LEDs to use.
3mm round flangeless ones is my best bet so far, but further specification I lack. I ordered these off of ebay, I'm thinking they should work.
http://www.ebay.com/itm/221268675895?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
Any feedback is well appreciated!
Hugs
Offline kohi
Re: Modding Poker 2 with LEDs
« Reply #1 on: Fri, 26 September 2014, 23:50:59 »
people say that the 2x3x4mm square leds work well with cherry switches, though I can't really say cause I haven't tried them
here are some old threads that talk about it, good luck :thumb:
http://geekhack.org/index.php?topic=55520.0
http://geekhack.org/index.php?topic=54702
Offline keypro
  • * Commercial Vendor
« Reply #2 on: Sat, 27 September 2014, 00:35:31 »
2x3x4 rectangle led fits nicely with my Poker 2 pbt version.
Offline frosty
  • jukebox hero
« Reply #3 on: Sat, 27 September 2014, 10:47:30 »
I successfully added a magenta 3.2V 3mm led into my poker non-led version. It's a little dim but hey it works. KBC covered the led holes with solder so you should get rid of those first.
Offline honoka
« Reply #4 on: Sun, 28 September 2014, 18:13:53 »
Thanks for all the answers guy's. The 3mm flangeless ones got delivered faster than I expected so I just poped them in. Works great. Thank for the feedback :)
Offline Tiramisuu
« Reply #5 on: Sun, 28 September 2014, 20:10:54 »
sip sockets :)
Keyboard error F1 to continue.
Poker 2, Gherkin, Lets Split, Planck, Filco
Offline honoka
« Reply #6 on: Sun, 28 September 2014, 20:30:24 »
Those can be nice, but that would mean you'd have to desolder every single switch.
And I never plan to switch from white LEDs anyway ^^
Offline Tiramisuu
« Reply #7 on: Sun, 28 September 2014, 21:18:07 »
Yes but then you can use a plate that lets you open the switches for lubing as well as changing led colours with different key cap colour schemes  :)
Offline honoka
« Reply #8 on: Mon, 29 September 2014, 01:31:39 »
Yeah, but I don't think the need for a custom plate comes from the need to use sip sockets.
If I already had a custom plate I would consider it, but since I don't, I won't :)
