Author Topic: Need recommendation on two things! (Topre, alps and other)  (Read 2390 times)
Offline GL1TCH3D
« on: Sat, 13 September 2014, 13:41:03 »
My first question is regarding topre switches.
I understand that the rubber dome portion becomes more brittle over time. I have a stock Realforce 89s keyboard with 30g switches but lately I've been feeling them to be a bit too light. I was planning on putting it in storage but how should I go about doing this to preserve it?
Or can I get replacement domes for the future in case the stock ones dry out?
I assume some kind of vacuum seal would be best.
As for my second question do alps require upkeep and/or maintenance? I'm aiming for a medium profile board in TKL for home use and have been slightly ignoring alps for the time being =S
And lastly besides the GoN TKL are there any other solid higher end boards?
Not sure I want to go topre again (don't get me wrong, I'm definitely eying a 45g topre TKL) but wanted to explore some other options. Right now I'm enjoying my JD40 with MX clears stickered and I assume lubed.
I'd really want ergo clears on my board.
Thanks
Offline opensecret
  • 公开的秘密
Re: Need recommendation on two things! (Topre, alps and other)
« Reply #1 on: Sat, 13 September 2014, 20:42:47 »
On your Alps question, I'm typing on a 25-year old Northgate (Omnikey Ultra with white Alps) which has seen a lot of use but no maintenance, and it works like a champ, though I should do some cleaning of the keycaps real soon now.
IBM Model M |Matias Mini Quiet Pro|Plum 84EC-S|RealForce 103U-UW & 87U-UW|Omnikey Ultra T| 2 Omnikey Ultras| WASD V2| Xmit Hall Effect|
Offline FrostyToast
  • Litshoard
« Reply #2 on: Sat, 13 September 2014, 21:44:18 »
You could go with a KMAC for a high end TKL. Expensive, but it has very good quality
There is also the Duck Orion.
Quote from: elton5354
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #3 on: Sat, 13 September 2014, 21:51:53 »
no model m yet?
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline FrostyToast
  • Litshoard
« Reply #4 on: Sat, 13 September 2014, 21:53:27 »
no model m yet?
SSK for TKL. SSK is best TKL.
Offline GL1TCH3D
« Reply #5 on: Sat, 13 September 2014, 22:09:40 »
Both look really nice but dang o.o $410 for the kmac without switches or building
« Reply #6 on: Sat, 13 September 2014, 22:18:12 »
Topre switches are rated for something like 30 million presses.  This is unlikely to be achieved in the normal life span of a keyboard.
Unless, perhaps, you live in an extreme climate.
Offline GL1TCH3D
« Reply #7 on: Sat, 13 September 2014, 22:52:27 »
Ah I don't mean that I mean that the rubber domes of topre switches dry out which is something I want to avoid if I'm going to store it for a few years or more
Offline ComradeSniper
  • HHKB Pro
« Reply #8 on: Sat, 13 September 2014, 23:01:33 »
Knock out two birds with one stone and get a Kingsaver.
Offline GL1TCH3D
« Reply #9 on: Sat, 13 September 2014, 23:15:00 »
Looks really dang nice! Though I'm unsure of what alps switches to get
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
« Reply #10 on: Sun, 14 September 2014, 17:06:19 »
Get vintage blue Alps! :-P
Bore Awards
