Author Topic: Filco Zero - How loud is it?  (Read 3189 times)
Offline iggysaps
« on: Wed, 17 June 2009, 07:37:51 »
I hear that white alps are fairly loud.  How loud is the filco zero?  I just visited elitekeyboards and their stock of filco zeros has run dry.  I think its safe to assume that someone from these boards purchased a filco zero.
How loud is it compared to BS, Blue cherries, etc...
Thanks is advance!
Cherry G84-4100 cherry ML switches
Cherry G80-3000 blue cherries
Dell AT101W (2)
Solidtek ASK-6600
Unicomp Spacesaver buckling spring
Key tronic designer P2
Offline ch_123
« Reply #1 on: Wed, 17 June 2009, 07:58:24 »
Check out Bigpook's review.
The consensus was that they were in and around the noise level of a buckling spring board.
Offline bigpook
« Reply #2 on: Wed, 17 June 2009, 08:26:12 »
There seems to be a fair amount of interest for the filco with white xm's. Now that elitekeyboards is selling them maybe some members will pick one up. The pricing sure is good. I am curious as to what other people think of it. I found them to be a bit balky and they tired my fingers. I loved the sound though. So if any members here score one, please do a review. : )
Offline megarat
  • (Not My Real Name)
    • http://www.megarat.com
« Reply #3 on: Fri, 19 June 2009, 17:41:01 »
Quote from: ch_123;96987
I concur, the noise level and quality are similar, with the Filco Zero having a slightly higher pitch.
Home/Work:  Custom Filco FKBN87Z/EB and SGI 041-0136-001 chimera (original white ALPS, not simplified, rubber-dampened)
Gaming:  Wolfking Warrior with custom-colored layout, HHKB Lite 2 (Rubber dome)
Offline patrickgeekhack
« Reply #4 on: Thu, 25 June 2009, 14:29:40 »
Could someone please post a sound clip? Or is there one already?
Cherry MX Blue: Cherry G80-3000, Das Keyboard Model S Ultimate
Cherry MX Brown: Filco Majestouch, Compaq MX11800
ALPS: AEK, AEK II, Northgate Omnikey Ultra, Matias Tactile Pro 4
Topre: Realforce 103UB
Buckling Spring: IBM Model M 1390120
Previous owned: Unicomp Customizer 104, IBM Model M 1390141, ABS M1
Offline Repoman
« Reply #5 on: Thu, 25 June 2009, 15:19:24 »
I think myself and bigpook ended up with the first revision of the keyboard which has - in my opinion - some fairly serious flaws.
Lack of volume was not one of them.
And in the ballpark of buckling springs is about right.
Offline itlnstln
« Reply #6 on: Thu, 25 June 2009, 15:22:35 »
I would imagine it sounds like this 'board (it sounds like my Northgate, so I would think it's at least close): http://geekhack.org/showwiki.php?t=4820
Offline shrap
« Reply #7 on: Thu, 25 June 2009, 15:30:50 »
I have a Northgate Evolution with real Alps, and I'd say they're a little less loud as Cherry Blues, but the same high-pitched noise. BS is more clacky but not as high-pitched, and I don't find them as intrusive.
« Reply #8 on: Thu, 25 June 2009, 15:34:10 »
Quote from: itlnstln;99170
That's very loud.
Offline itlnstln
« Reply #9 on: Thu, 25 June 2009, 15:42:41 »
My Northgate is incredibly loud.  Much louder than my Ms.  That's pretty much the only reason I don't use it anymore (that, and I like brown Cherrys better).  It's a great switch, but it's loud as hell.
