Author Topic: Recently Modded my Ducky 9008 How good are the Ebay Usb Cables  (Read 1526 times)
Offline Owntrolf
« on: Sat, 13 September 2014, 21:30:00 »
I modded my Ducky 9008 so that most of the LEDs on the edge are white.
Also I made a diffuser for the RGB LEDs by having 3 clear O rings on them and having a piece of white plastic over it
Currently I'm also planning to get a braided microusb cable but im not sure if the ones on Ebay are good or not
Offline katushkin
  • Too Keycool for School
  • Just the guy
Re: Recently Modded my Ducky 9008 How good are the Ebay Usb Cables
« Reply #1 on: Sat, 13 September 2014, 21:39:29 »
Depending on where you live, there are some great guys over in the marketplace who specialise in braided/sleeved cables.
Pexon is THE MAN in the UK/Europe. Zeal is your POC in Canada/NA. Elsewhere I'm not so sure. (Edit: And Mimic too)
I would trust either of these guys over anything on eBay, even if it will cost you a little more.
Offline epzy
  • HHKB Fiend
  • ded
« Reply #2 on: Sat, 13 September 2014, 21:39:33 »
Check out mimic cables for some good quality cables: http://geekhack.org/index.php?topic=36065.0
Offline Owntrolf
« Reply #3 on: Sun, 14 September 2014, 13:41:51 »
Is it also worth to clean off the rosin residue off the solder areas?
