Author Topic: Any Idea what type/brand of keyboard is this?  (Read 1856 times)
Offline Rogbi
« on: Mon, 15 September 2014, 01:35:03 »
this is mechanical ?
TIA!
« Last Edit: Mon, 15 September 2014, 01:41:36 by Rogbi »
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
Re: Any Idea what type/brand of keyboard is this?
« Reply #1 on: Mon, 15 September 2014, 01:36:02 »
Broken image
Offline Rogbi
« Reply #2 on: Mon, 15 September 2014, 01:42:14 »
image fixed. :)
Offline Oobly
« Reply #3 on: Mon, 15 September 2014, 01:53:59 »
Considering the layout and what I can see of the keycap profile it may be mechanical. I know some of the Amiga layout (with the Big Ass Enter key) boards had Cherry MX switches. There were also some rubber dome OVER sliders boards, Mitsumi mechanicals, NMB Hi-Teks and some standard rubber domes. So it's hard to know without seeing what the top of the switches look like under those keycaps.
If it's a board you're considering buying, ask the seller to pull a keycap so you can see the switch type before commiting to a purchase.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline Rogbi
« Reply #4 on: Mon, 15 September 2014, 02:03:22 »
Thank you good sir.
Offline jacobolus
« Reply #5 on: Mon, 15 September 2014, 03:12:44 »
From the keycaps it looks pretty Alpsy.
If you can tell us the model number of the keyboard (get a picture of the label on the back) we could give you a better idea. Or obviously getting a picture of a switch top would tell you all you need to know.
« Last Edit: Mon, 15 September 2014, 03:15:26 by jacobolus »
Offline Magna224
« Reply #6 on: Wed, 17 September 2014, 10:01:08 »
That's my vote too.
If you live in AZ you can try my keyboards. I usually keep plenty of different ALPS and MX and buckling springs.
Offline Firebolt1914
  • POM Overlord
« Reply #7 on: Wed, 17 September 2014, 10:02:14 »
Is there the back part of the case? If so, is there any serial number?
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
« Reply #8 on: Wed, 17 September 2014, 13:26:11 »
I don't want to be too hasty in judging as it could be a spring-over-membrane keyboard (like the Oriental Tech OK-100M) or even a KPT or KPT-like keyboard (Podworld, Micronorth etc). It has the look of a KPT/KPT-like keyboard.
Bore Awards
