Author Topic: LED's interfering with keycaps?  (Read 2945 times)
Offline Jixr
« on: Tue, 16 September 2014, 08:56:18 »
Hi everyone, I just built up a new keyboard, and I wired in leds on it ( 2x2x3 square ones ) and it feels like the leds are rubbing up on the inside of the caps.
I'm using vortex thick dub shot pbt caps, and it doesn't quite feel right. I'm using some vintage blacks, and it feels like there is a good bit of resistance when typing compared to my other keyboard with blacks.
I'm thinking the thick caps are rubbing the leds on their way down.
Anyone else experience this?
Offline Lastpilot
  • Power stance
Re: LED's interfering with keycaps?
« Reply #1 on: Tue, 16 September 2014, 09:10:02 »
Yep, in fact, WinterIsle sanded down his LED's so that they wouldn't rub on the inside of keycaps.
http://geekhack.org/index.php?topic=35864.msg1451228#msg1451228
Offline Jixr
« Reply #2 on: Tue, 16 September 2014, 09:14:44 »
Hm.. sanding will diffuse them quite a bit, But I'm not using backlit caps so it wont be too bad.
Thankfully I got those little prongs where I can easily change LED's, so I'll just pull them out and sand the edge a tiny bit and see if that helps.
« Reply #3 on: Tue, 16 September 2014, 10:15:41 »
If you switch to really fine-grit sandpaper, it will diffuse them much less, but will be a lot more work on your part. I wouldn't worry about it: the diffusion effect should give you a little more even lighting, but it will most likely have no visible effect once keycaps are installed.
Offline Jixr
« Reply #4 on: Tue, 16 September 2014, 10:34:26 »
Yeah, I have some 2000 grit sand paper, shouldn't be that bad to do them all, and I don't think I need to sand them as aggressively as the user in the pic above did.
Offline margo baggins
  • Dungeon Dweller
  • Get back to work!
« Reply #5 on: Tue, 16 September 2014, 11:01:33 »
use dremel with grinding wheel, i've done it loads of times.
1.8mm LED do not foul any caps. Though they can be quite hard to find some colours locally. GON sells them all but then the shipping is killer.
I got boards.
Offline Jixr
« Reply #6 on: Tue, 16 September 2014, 11:51:42 »
I don't have a dremel, but I should be able to sand them out by hand to where they clear, its a 60% board, so its not so bad.
And I'm currently waiting for some cyan leds to come in the mail from china that I'll probably need to sand down as well.
Offline 0100010
  • Not Sure
« Reply #7 on: Tue, 16 September 2014, 12:59:56 »
2000 grit paper, by hand; will take a while.
Maybe try some 400 or 600.
Offline wes1099
  • Technology and Dog Enthusiast
« Reply #8 on: Tue, 16 September 2014, 14:48:04 »
I do the same for non-flangeless round LEDs.
[Leopold FC660C]     [GON NeRD 60]    [Infinity Keyboard]    [ Model M Silver Label]
[Topre 45g Silent]     [Gateron Black]    [Cherry MX Black]     [Model Number 1390636]
        [May 20, 1987]
Offline Jixr
« Reply #9 on: Tue, 16 September 2014, 16:57:03 »
yeah, I'll dig around in my tool box and see what I've got. I'd love a dremmel, but man those boogers are expensive for as little as I would use it.
« Reply #10 on: Wed, 17 September 2014, 00:50:19 »
Valuable tips here from a Maker!
