Author Topic: Soft Landing Pads with LED's?  (Read 2727 times)
Offline Aidenknives
« on: Wed, 17 September 2014, 17:32:51 »
Does anyone know if they get in the way of the light shining through? Looking to put some on an LED board but don't want to get them if it is just going to ruin the LED effect. Anyone have any experience?
Offline spiceBar
    • ChessTiger.com
Re: Soft Landing Pads with LED's?
« Reply #1 on: Wed, 17 September 2014, 20:13:38 »
You guessed right, they do get in the way. I don't recommend landing pads if your keyboards has backlighting.
O-rings will interfere less with backlighting, but it will still be visible.
Offline Oobly
« Reply #2 on: Thu, 18 September 2014, 01:47:54 »
Trampoline mod.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #3 on: Thu, 18 September 2014, 07:34:25 »
I used clear/translucent white o-rings from eBay on my Shine 2.
Black o-ring:
Look at the letter O.  Take notice of the bottom part of the letter O.  There's a slight shadow with the black o-ring.
Clear/translucent white o-rings:
clear/translucent white o-rings vs black o-ring:
Offline Aidenknives
« Reply #4 on: Thu, 18 September 2014, 19:20:40 »
Black o-ring:
Are these clear or white? - https://www.massdrop.com/buy/tex-cherry-mx-rubber-o-rings
Offline wes1099
  • Technology and Dog Enthusiast
« Reply #5 on: Thu, 18 September 2014, 19:23:41 »
Black o-ring:
They are translucent, so light can get through but they are not perfectly transparent.
[Leopold FC660C]     [GON NeRD 60]    [Infinity Keyboard]    [ Model M Silver Label]
[Topre 45g Silent]     [Gateron Black]    [Cherry MX Black]     [Model Number 1390636]
        [May 20, 1987]
Offline exitfire401
  • The Force is Re/\l
« Reply #6 on: Thu, 18 September 2014, 19:31:35 »
Soft landing pads make no difference in light at all. I used them on my pink backlit pure for the entire time I had it. Not sure where you got your information from.
Offline spiceBar
    • ChessTiger.com
« Reply #7 on: Fri, 19 September 2014, 08:25:04 »
Where I got my information from? A hippo told me a tiger had seen an elephant who told him that...
Seriously: I use landing pads (soft and firm) or O-rings in all my keyboards, so I know a little bit about them.
I have at least 3 backlight keyboards in which I have tried both: 2 Pure Pro and one Poker 2. All have white backlighting.
The landing pads have a tendency to rotate on the key stems, and depending on how they end up, some keys will be more obscured than others.
It is possible to avoid the problem partially by cutting the corners of the landing pads.
With landing pad or O-rings, you may not notice any adverse effect on your keyboard, it all depends on the position of the LEDs and the path the light follows inside the keycap.
As a general rule, however, I would expect landing pads and even O-rings to interfere with backlighting. You can't just bet there will be no interference, you need to test it.
