Author Topic: TKL MX Blue mech with Costar stabs?  (Read 5122 times)
Offline TechnoGarrett
  • I have more internet points than you
« on: Thu, 18 September 2014, 16:26:01 »
Doesn't need to light up, and I'm not brand loyal. I'm just Costar stab loyal :D
Re: TKL MX Blue mech with Costar stabs?
« Reply #1 on: Thu, 18 September 2014, 16:26:30 »
QFR... Filco... :)
Offline saturnotaku
« Reply #2 on: Thu, 18 September 2014, 16:32:28 »
« Reply #3 on: Thu, 18 September 2014, 17:32:49 »
I vote Filco
« Reply #4 on: Thu, 18 September 2014, 17:33:28 »
I vote Filco
Thought you'd go for KUL or something
« Reply #5 on: Thu, 18 September 2014, 17:53:37 »
« Reply #6 on: Thu, 18 September 2014, 17:54:57 »
QFR... Filco... :)
Woops seems as if I can't edit posts. hmm.
But does the Rapid-i have Costar? I've been through 3 mushy Cherry keyboards now, I need Costar stabs.
EDIT: My retardation kicked in, I see "modify" now, sorry, lol.
So can I put these Ducky caps http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=862
On this keyboard barebones kit? http://www.wasdkeyboards.com/index.php/products/mechanical-keyboard/wasd-v2-87-key-barebones-mechanical-keyboard.html
« Last Edit: Thu, 18 September 2014, 18:02:54 by TechnoGarrett »
Offline frosty
  • jukebox hero
« Reply #7 on: Thu, 18 September 2014, 18:03:27 »
Yah, I vote for filco.
Alternatively you can get a Razer Blackwidow, but I highly suggest you don't.
« Reply #8 on: Thu, 18 September 2014, 18:06:53 »
I vote Filco
KUL is cherry stabs, and the MX blue version isn't out yet
« Reply #9 on: Thu, 18 September 2014, 18:11:59 »
I would never sink to Razer level.
That's like, further than the bottom of the barrel.
« Reply #10 on: Thu, 18 September 2014, 18:12:46 »
the 2013 wasn't trash
all the other ones are/were
Offline frosty
  • jukebox hero
« Reply #11 on: Thu, 18 September 2014, 18:18:18 »
Ok-ish quality but the price does get justified.
Just my 2C on the BW 2013.
« Reply #12 on: Thu, 18 September 2014, 18:19:18 »
I vote Filco
Oooo true I completely forgot the main point here was costar stabs, ignore me.
Instead I'll direct you to my original post which you don't have to ignore. Filco/QFR :)
« Reply #13 on: Thu, 18 September 2014, 18:41:20 »
I vote Filco
But does the QRF-i have Costars? I've seen a few reviewers saying it does, and some saying it doesn't. But the OEM is Costar, so it should have Costar stabs, right? Or am I missing something?
« Reply #14 on: Thu, 18 September 2014, 19:42:55 »
I vote Filco
I believe it has Costar... not sure though.
You said "Doesn't need to light up" so... why not just QFR
« Reply #15 on: Thu, 18 September 2014, 21:00:09 »
OEM is costar, it should be costar stabs
« Reply #16 on: Thu, 18 September 2014, 21:13:13 »
I vote Filco
Because I can't seem to find the QFR anywhere with Blues from a reputable dealer. Amazon only sells them from third parties. MechanicalKeyboards.com doesn't have them, and I'm not sure of any others that do.
« Reply #17 on: Thu, 18 September 2014, 21:31:34 »
Quick Filco Rapid
Offline Flyersfan1
  • Hi!
« Reply #18 on: Thu, 18 September 2014, 21:38:33 »
I vote Filco
Rapid-I comes with plate mounted cherry stabs.  Carter(CM Rep here on GH) mentioned the non-backlit QFR were in shortage at the moment due to switch availability.  I'd say WASD might be your best bet for a readily available TKL with costar stabilizers.
Quote from: Photekq
« Reply #19 on: Thu, 18 September 2014, 21:50:22 »
I recommend phantom / diy.
Offline Oobly
« Reply #20 on: Fri, 19 September 2014, 02:59:23 »
... I've been through 3 mushy Cherry keyboards now, I need Costar stabs.
Clip the bendy tabs on your Cherry stabilisers = better than Costar stabs. Same crisp feel, but easier to replace caps, less rattly, and less prone to sticking on thick keycaps.
http://geekhack.org/index.php?topic=34759.0
Buying more keycaps,
it really hacks my wallet,
but I must have them.
« Reply #21 on: Fri, 19 September 2014, 03:27:02 »
I vote Filco
That's what I'm probably going to do. $95 for a TKL is not that bad, and I can get a nice blank Ducky keycap set.
And I did clipped my stabs on my KBT Pure Pro and they still just didn't feel right, but I tried my friend's QFR and it was perfect. I didn't have to wait for the switch to pop, it was almost instant.
