Author Topic: IBM M13  (Read 1556 times)
Offline Synjin
IBM M13
« on: Thu, 18 September 2014, 18:51:00 »
I just recently made a purchase for an M13 keyboard which arrived today. This is my very first Model M keyboard and I wanted to know if all the switches should feel approximately the same and if it has ever happened to someone wherein the keyboard will click and register although the audible click sounds very off compared to all of the other keys when pressed. My left arrow key is doing this and it is bugging me T_T.
P.S. The left arrow still feels exactly the same as others when actuated although the sound isn't quite the same and is a lot less audible.
Offline E TwentyNine
    • Some of My Keyboards
Re: IBM M13
« Reply #1 on: Thu, 18 September 2014, 19:07:40 »
Pull the key and reseat it.  Tilt the keyboard forward (away from you) when reseating it so the spring in the barrel stands up straight.
Offline ComradeSniper
  • HHKB Pro
Re: IBM M13
« Reply #2 on: Thu, 18 September 2014, 19:15:50 »
There will be a little variance in the feeling of each key, that's just how it goes with buckling spring. If anything feels really different, the method E twentynine mentioned should fix it.
Re: IBM M13
« Reply #3 on: Thu, 18 September 2014, 19:29:18 »
If not, you can swap the pivot plate / spring assembly and bolt mod it which should really fix the issue. It is quite overkill for most though.
Offline Synjin
Re: IBM M13
« Reply #4 on: Thu, 18 September 2014, 19:56:29 »
I jsut tried E TwentyNine's suggestion and it just feels like the spring is a lot less stiff on that key compared to the rest of the board
Re: IBM M13
« Reply #5 on: Thu, 18 September 2014, 20:43:48 »
The next step I would do is pull the spring off that key, and off a key you don't use much ( one of the Fn, Pause/Break, etc) and swap them.
It's fairly simple, think there's a guide around here somewhere via the chopstick method...
Offline Synjin
Re: IBM M13
« Reply #6 on: Thu, 18 September 2014, 21:10:04 »
Thanks. I will do that as soon as I get done with my program LOL. I shouldn't have any problems looking for the thread guide within our forums.
