Author Topic: does anyone make a spacebar for the ducky shine 3 that covers the LEDs?  (Read 1847 times)
Offline hugz
The standard ducky shine 3 spacebar needs to be about 1mm lower at the front in order to properly cover up the LEDs behind. As is, the LEDs are clearly visible. depressing the spacebar slightly hides the LEDs
does anyone make a spacebar that's a bit lower at the front so that I don't have the LEDs shining bright in my eyes?
« Last Edit: Fri, 19 September 2014, 01:27:57 by hugz »
Offline limitz
  • "the old gods stir and will not let me sleep..."
Re: does anyone make a spacebar for the ducky shine 3 that covers the LEDs?
« Reply #1 on: Fri, 19 September 2014, 08:29:02 »
Reverse your spacebar.
Mmm... machined aluminum
