Author Topic: Assigning keys in OSX  (Read 2030 times)
Offline phototristan
    • https://www.youtube.com/phototristan
« on: Thu, 18 June 2009, 22:05:19 »
Can OSX differentiate between the left and right ALT keys so that they are different?
Is there any way to assign the Windows menu key (to the left of the right Ctrl key)  to do anything? On Mac, I notice it does nothing. I'd like to be able to at least assign it some function.
Offline sixty
    • http://deskthority.net
« Reply #1 on: Thu, 18 June 2009, 22:19:39 »
It's not an easy task on OSX, but there are a few helpful tools. Check out the following links and see if they help:
http://www.kodachi.com/software/fKeys/
http://doublecommand.sourceforge.net/
Offline wellington1869
« Reply #2 on: Thu, 18 June 2009, 22:24:23 »
i've had good luck reassigning keys with spark: (its actually free, amazingly)
http://www.macupdate.com/info.php/id/14352
using: ms 7000/Das 3
« Reply #3 on: Fri, 19 June 2009, 10:34:59 »
Thanks for the suggestions!
