Author Topic: Anyone with Orbweaver know how to do this?  (Read 7423 times)
Offline FinancialWar
« on: Fri, 19 September 2014, 17:08:30 »
at 14.05 of the video
The guy said that Razer Synapse 2.0, you can basically turn the 20 keys to 40 or even 60 keys if you assign the thumb keys as shift keys.
But I can not find that option anywhere in the Synapse 2.0, anyone with Orbweaver know how to do this?
Offline oscillik
    • music podcasts
Re: Anyone with Orbweaver know how to do this?
« Reply #1 on: Fri, 19 September 2014, 17:14:53 »
assign one of the thumb buttons to momentary keymap switch.
there you go
Keymacs A620N-Rev.A with Alps SKCM Salmon switches
« Reply #2 on: Fri, 19 September 2014, 17:42:23 »
okay thanks. Is switching keymap the only way?
But there is no way of getting synapse to recognize them as individual input as you can do with the g-shift on the Logitech G600?
Offline oscillik
    • music podcasts
« Reply #3 on: Fri, 19 September 2014, 17:43:39 »
yup that's the only way, unless you also have a Synapse 2.0 enabled Razer Mouse, in which case you can use a mouse button as a modifier to switch keymaps momentarily
Offline darla
« Reply #4 on: Wed, 24 September 2014, 07:30:28 »
I've had mice with the multiple click problem and it was just dirt built up around the edges of the "button", you're probably cleaner than i was [am] but maybe run a knife along the join to see if there is any crap in there.
Always look for the simple solution first :)
