Author Topic: What size LED for Cherry Switches?  (Read 27885 times)
Offline awhitedev
« on: Fri, 19 September 2014, 18:16:44 »
I'm in the process of modding a QFR and would like to change out the bright LEDs with something a little more subtle. This might sound like a stupid question but does anyone know what size LED fit in a cherry switch?
I was looking at these... but they look a little too big:
http://www.amazon.com/gp/product/B004UZCMRK/ref=gno_cart_title_4?ie=UTF8&psc=1&smid=A3AGVPZHIH41EE
Thanks
Offline qwack
Re: What size LED for Cherry Switches?
« Reply #1 on: Fri, 19 September 2014, 18:57:02 »
These 5mm LEDs are indeed too big. Cherry MX switches are made for flangeless 3mm LEDs; 2x3x4mm LEDs work too, as well as 1.8mm LEDs.
For further reference: http://geekhack.org/index.php?topic=54702.0
Pure Pro w/MX Red - [review]
« Reply #2 on: Fri, 19 September 2014, 20:01:04 »
3mm, or 2x3x4. I think you want 3.3v as well
Offline awhitedev
« Reply #3 on: Fri, 19 September 2014, 20:06:21 »
Thanks guys! This helps...
So it looks like ebay is the only place to buy these... is that right?  Seems kind of a pain to ship something all the way out of Hong Kong. I don't think local electronics stores sell flangeless 3mm or 2x3x4 mm square leds like this. At least I've never seen one anyways.
Offline Owntrolf
« Reply #4 on: Sat, 20 September 2014, 13:23:01 »
http://www.ebay.ca/sch/i.html?_odkw=flangeless+LED&_from=R40|R40&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313&_nkw=flangeless+3mm&_sacat=0
 Even though it takes like 2 weeks to ship to you its all k.
Works completely fine
Offline 0100010
  • Not Sure
« Reply #5 on: Sat, 20 September 2014, 14:05:03 »
If I were to put LEDs on a Cherry switch, I would use 1.8mm LEDs, to ensure no interference with any cap selected.
« Reply #6 on: Sat, 20 September 2014, 21:32:19 »
you can use LEDs with a much lower Vf. In most designs any LED from 1.6 (red) to 3.5 (blue) will work.
This is a good idea, as even 2*3*4 has issues with some extremely thick keycaps, but unfortunately 1.8mm is not available in all colours.
