Author Topic: HH wont work with USB/PS2 adapter?  (Read 2126 times)
Offline lam47
« on: Fri, 19 June 2009, 15:23:52 »
I can't seem to get it to work. I re set the PC and everything but it does not get picked up at all.
Any ideas?
Keyboards. Happy Hacking pro 2 x2. One white one black. IBM model M US layout. SGI silicone Graphics with rubber dampened ALPS. IBM model F. ALPS apple board, I forget what it is. And some more I forget what I have.
Typewriters. Olivetti Valentine. Imperial Good Companion Model T. Olympia SM3
Offline itlnstln
« Reply #1 on: Fri, 19 June 2009, 15:28:44 »
I thought the HHKB was a USB-only keyboard.  I don't think it supports PS/2.  I could be completely wrong, too, but I thought I just read that in the thread about the HHKB not waking up a PC in suspend.
Offline lam47
« Reply #2 on: Fri, 19 June 2009, 15:31:37 »
You are most likely right itlnstln. I did not think of that! I have been trying to find away around how the keyboard will not input anything when windows first boots.
You have to press lots of keys for few seconds before it starts working.
Has always done it and its a bit annoying.
Offline itlnstln
« Reply #3 on: Fri, 19 June 2009, 15:34:48 »
I have seen where motherboard support for USB input devices is pretty hit-or-miss.  I used to hate trying to dig out a PS/2 keyboard when I needed to do stuff in a DOS prompt (boot disc), or something.  I don't know why USB support can't be better, especially since many of the legacy connectors are getting phased out (like PS/2).
Offline o2dazone
« Reply #4 on: Fri, 19 June 2009, 15:58:56 »
