Author Topic: Detachable cable mod for my filco  (Read 2015 times)
Offline billiob
« on: Mon, 22 September 2014, 14:47:20 »
After looking at Zeal's cables, I wanted to get one!
The main issue is that I own 2 filco tkl and their cables are not detachable. That's why I wanted to mod one!
I used an old micro usb extension I had.
I soldered the cables from the connector to the original cables and then taped them. I also cut the case to make some room for the connector:
The result:
At first I wanted to put the connector on the side but I couldn't put it that way because of the pcb.
Offline tjcaustin
  • King Klaxon
    • Buy stuff
Re: Detachable cable mod for my filco
« Reply #1 on: Mon, 22 September 2014, 14:50:08 »
I would use heatshrink instead of electrical tape, but not bad.
Offline billiob
« Reply #2 on: Mon, 22 September 2014, 14:52:40 »
I would have preferred to use heatshrinks but I didn't have any.
