Author Topic: officailly de-lurking, even though you all likely know me from the irc.  (Read 1780 times)
Offline cinnamonrollz
  • buckle master 5000
Anyway, now that I've changed the eye-bleed red and black theme I will be alot more active here. I can bear to read the site for more than 5 minutes. For those who don't already know Im the annoying newb thats not leaving anytime soon.
Ive only ever typed on buckling spring, vintage t alps, and kalih switches and probably wont try alps or cherry any time soon because of how cheap I am.
Current keyboards:
1391401 restored by phosphorglow with remote desktop cable
1393464 (the one with the purple font) with slightly damaged remote desktop cable
some random 122 key m with no poped rivets
wheel writer 3 keyboard with factory defect missing rubber mat
oh and one of those $40 vintage t alps keyboards
http://www.ebay.com/itm/380994154944
for the $40 you are getting caps that might be mx compatible, new top caps for a stretched kishy, and official ibm key cap puller. I was dissapointed.
oh, and also Ive got a 107 key 4704 coming soon!
Re: officailly de-lurking, even though you all likely know me from the irc.
« Reply #1 on: Mon, 22 September 2014, 17:46:07 »
Yeah, you were spamming there too... ;)
Three identical threads, dude! One is enough.
Offline SL89
« Reply #2 on: Mon, 22 September 2014, 17:46:55 »
hi from the irc! and what is that chinese monster, idk if i really want it or really hate it. good find either way.
« Reply #3 on: Mon, 22 September 2014, 18:41:11 »
Welcome to Geekhack!
A fan of buckling spring, perhaps?
