Author Topic: 1391401 20 May 87  (Read 2207 times)
Offline Hak Foo
  • Make America Clicky Again!
1391401 20 May 87
« on: Sat, 20 June 2009, 00:53:21 »
I found this one at the local thrift shop; $4 was worth it for the vintage.
It has a detachable cable (PS/2), and a different card than later Ms (the LED cable isn't a film or ribbon cable, but rather a bundle of wires, and the board is grounded to the metal plate with a thick connector.
It had about six rivets in the case (one fell off as I brushed the bottom of the board's riveted panel), and a seperate, large label on the bottom of that panel.
Also, the numpad + and Enter are stabilized.
It was missing F8 and F11 caps; I'm using a Lexmark donor for those... but the legends line up poorly.
The old legends are so sharp compared to Unicomp's.
I'm de-grunging.  Pics to follow once I get my replacement card-reader.
« Last Edit: Sat, 20 June 2009, 01:01:46 by Hak Foo »
Overton130, Box Pale Blues.
Offline Hak Foo
1391401 20 May 87
« Reply #1 on: Sun, 21 June 2009, 18:31:55 »
Okay, writing the followup post ON the '87 model.
It cleaned up fairly well with some Oxi-Clean and agitation on the keycap bag.  There were some spots of orangey-brown goo, and it had wicked inside some of the two-piece keys.  I suspect this keyboard was decommissioned after a Coke accident.  Given the vintage, possibly New Coke.
It feels a bit duller-- a touch quieter, a touch more pressure than the Customizer 104 next to it.  It lost two more rivets during the cleaning process (total: 8 as far as I know)
Relevant photos:
* Proof I'm not blowing smoke about the date.
* Stabilizer bars for numpad + and enter.
* Partial reassembly.  The Das M.  This is the first one I've seen with all the key heads the same colour.
* LED panel.  Note the individually-wired cable.
* Inner assembly label.  Our new lesson:  Someone who signed his initials "W" is responsible for those rivets that pop.  We can track him down now! :)
Oddity:  The |\ key sits a littele higher than others in its row.  This is also true or the Customizer, but it's less prominent.
I had to steal spare keycaps for F8 and F11 from a later board.  The F8 text is too low, and the F11 too delicate)
Offline nowsharing
  • Swoop
1391401 20 May 87
« Reply #2 on: Mon, 22 June 2009, 15:33:51 »
Wow, what a nice find. It looks like you've cleaned it up well. Talk about a great trip to the thrift shop, they're usually hubs of old technology, but an '87 M is quite a rarity.
Offline watduzhkstand4
1391401 20 May 87
« Reply #3 on: Mon, 22 June 2009, 15:57:35 »
that looks very clean, nice one
KEYBOARDS
Cherry Blue *Filco Tenkeyless w/ blank keys* w/ red ESC key thanks to Megarat
Cherry Red Noppoo Choc Mini
IBM Model M 1391401 12/15/88
Siig Minitouch w/ White Alps
SOLD
HHKB Pro 2 white w/ blank keys red ESC key and blank WASD keys
HHKB L-2
Cherry Brown Compaq mx11800
Dell AT101W
Cherry Red Leopold 104-key Otaku FC500RR/ABN
Offline Hak Foo
1391401 20 May 87
« Reply #4 on: Mon, 22 June 2009, 19:51:17 »
I'm hoping it holds up.  I had it hooked with the USB-PS/2 converter I used for a while before getting a native-USB Customizer, and it dropped out (didn't respond to any keys) until I pulled and replugged the assembly.  It could be the adaptor or mainboard, but I'm having a hard time to decide which one stays on the desk and which goes into spares.
