Author Topic: mkawa's long-term review of the CM Storm Novatouch TKL  (Read 33969 times)
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« on: Tue, 23 September 2014, 04:51:04 »
DISCLAIMER: this review sample was provided by CM-Rajiv. When Rajiv approached me about reviewing a novatouch sample, I told him that I was going to buy one anyway, but that I'd be happy to receive a review sample to review that could be then be used as a general sampler of Topre switches that could take a tour through the community. Rajiv then sent me two copies. Watch out for a Topre/Novatouch tour organized by dorkvader and cptbadass in the near future.
As some may know, I own exactly one keyboard: a 55g uniform Realforce 10th Anniversary. It's blue. I like it. When I first met Carter of CM Storm, he told me that they had worked out and were going to market a Topre switched board with MX-compatible cruciform stems. This was the first statement in our first ever discussion and I have been waiting and dying to buy one since then. When I finish with this long-term review, I'm going to buy one regardless of the conclusion of the review. I am probably the most biased reviewer you have ever met. OK, you have been warned.
WEEK ONE: first impressions
I received a gigantic brown box last week. I wasn't sure what was in it. When I opened it, it was full of butcher paper and more cardboard.
Oh, there were two black boxes in them. Each one contained a Novatouch TKL. OK, that makes more sense.
The packaging designed for the Novatouch is beefy. It consists of a large black box with inset black logos, black text and black foam inside. The box opens with a single black flap that is magnetized. Nice touch.
Inside, there was a black keyboard, a set of black o-rings and a nice wire keycap puller with a black handle. Does the packaging explode if you put white keycaps on the keyboard? Made a note to investigate this.
My first encounter with a Novatouch sample was the unit that CM-Nurumu brought to Keycon. Without a 55g reference, my feeling was that it actually felt like 55g and not 45g as the specs indicated. However, comparing a final production unit to my 55g 10ae, the Novatouch is definitely a 45g uniform. My feeling is that this is a good thing because the samples of the Leopold FC660C that I've tried have felt more like 30g; I have not been crazy about the 660C.
To be fair, my 55g 10AE sliders have been lubed with straight Krytox GPL206, but  one can still feel the dome actuation, and my 10AE feels a little heavier than Cherry MX Browns while the Novatouch feels very close to Cherry MX Reds. This feel is consistent across the Novatouch, which, I think, is another good thing that the 660C lacks. This speaks to a high level of quality control on the part of the Novatouch and possibly a different rubber formulation than the 660C. I'm completely speculating on this point.
I then pulled out a GIGANTIC LIGHT and read the Novatouch box. The front of the box indicates that the switches are made in Japan, presumably by Topre, and the back of the box indicates that the board is made in China. What this means in the context of a Topre switched board is that the entire internal assembly, which is a produced as a single unit, is made entirely in Japan, while the outer plastic casing and final assembly are likely done in mainland China.
The next day, I put the review sample in my bag and brought it to work. I removed the logitech 2mm travel rubber dome keyboard from my terminal and broke it in half (dear employer, I actually just put it on the floor, but I did so very forcefully). The Novatouch takes an (included) mini USB cable. The cable that comes with it is a pretty standard cable. Previous CM Storm cables that I've used have had plastic fiber braided outers, but this one is smooth with an elastomer outer. The mini USB side of the cable is a right angle, and the computer side is straight.
If you're familiar with the quickfire rapid, the casing and board feels substantially more hefty and solid. There is an overlaid inset on the rear that is a lighter gray with a relatively plain CM Storm logo on it. This indicates that the board chassis probably uses at least three pieces. The quickfire rapid, stealth, XT, etc. all use two, an upper and lower casing. Regardless, the Novatouch casing is noticeably smaller than my TKL realforce.
The keys on the keyboard are ABS, and seem like OEM profile. The legends are pad printed. Like the other keyboards in CM Storm's oeuvre, the included keys are placeholders for customized and premium keysets. Since the stems are MX-compatible cruciforms, any keycap set that fits an MX-compatible keyboard will fit on the Novatouch. After using the board with the included keycaps for some time, I will probably replace them with either GMK doubleshots or IMSTO's thick dyesub PBT caps.
Typing on the board does not set off fireworks. It is a little noisier than other Topre boards I've used, but not alarmingly so. It feels pretty natural and was immediately familiar. To me, to be quite honest, the Leopold 660C feels only slightly better than a membrane board. The leopold's actuation point is difficult to feel out, and the actuation form is far too light. Not so with the Novatouch. The CM Storm board gives good positive feedback. I assume the clackiness has more to do with the keycaps, but I will have to wait until I can pick up some beefier keys before determining whether this is true.
There are no LEDs on the Novatouch. I don't believe in caps lock or any other kind of lock on a keyboard, so this doesn't bother me in any way. If it bothers you, then that may be something you want to consider before buying.
So, I'm typing on the Novatouch at work, and mostly just doing work. This is a good thing. It integrated into my workflow with zero effort or annoyances. It feels good to type on. I like it.
NEXT: MORE TYPING! (it's a keyboard. I mean seriously.)
Offline epzy
  • HHKB Fiend
  • ded
Re: mkawa's long-term review of the CM Storm Novatouch TKL
« Reply #1 on: Tue, 23 September 2014, 05:00:41 »
Thanks for the review. :)
Very interesting to read how you feel about the FC660C, too.
Offline Belfong
« Reply #2 on: Tue, 23 September 2014, 05:26:53 »
Any MX CC you can plug on the Novatouch? Coz you know, a GeekHack keyboard is also to display CC, not just for typing.
« Reply #3 on: Tue, 23 September 2014, 06:02:52 »
+1 for CM-Rajiv!  Thank you for this opportunity for the community :)
« Reply #4 on: Tue, 23 September 2014, 06:53:13 »
Is all of this experience with only one of the boards? Since you received two I am curious if there is any variation between them.
Offline mkawa
« Reply #5 on: Tue, 23 September 2014, 07:27:20 »
I haven't opened the other one yet
« Reply #6 on: Tue, 23 September 2014, 07:33:17 »
Can you swap out one of the modifiers from your Novatouch to your 10AE and vice versa? And does the Novatouch have that rubber "velvet" finish?
« Reply #7 on: Tue, 23 September 2014, 07:36:55 »
No pics?? I had to actually read!  :confused:
As epzy said, very interesting to read that you dislike the 660C so much. But it's great to see that you're pleased with the novatouch build quality, that's a huge plus.
Maybe it's time for me to get one...
In the end though, 10AE or novatouch?
Offline Flyersfan1
  • Hi!
« Reply #8 on: Tue, 23 September 2014, 07:38:09 »
The stabilizers are interchangeable.  The only unfortunate thing this that the spacebar spacing on the HHKB/Realforce is slightly shorter than the Novatouch, meaning people swapping the stems into a HHKB will have a difficult time finding an aftermarket spacebar.
Quote from: Photekq
« Reply #9 on: Tue, 23 September 2014, 07:39:28 »
The spacebar is an odd size? Interesting. Thanks Flyersfan1 :)
Offline mkawa
« Reply #10 on: Wed, 24 September 2014, 04:40:11 »
day 4. i was very angry yesterday and took it out on the poor novatouch. my officemate asked me to tone it down. conclusion: it is possible for the novatouch to make noise. hard to believe, i know ;D
Offline Latin00032
« Reply #11 on: Wed, 24 September 2014, 07:14:55 »
This is the first review where I feel like 660c is considered "bad".
I have a RF 55g and the 660c.
I'm not a topre veteran but the fc660c felt good to me. Not as good as the 55g RF. But, once I put the 55g domes in the 660c, it became my go to topre.
I haven't tried the hhkb, yet. I want to try it to see how it compares. I hear it's a completely new experience.
Offline mkawa
« Reply #12 on: Wed, 24 September 2014, 11:20:04 »
note to self. oem profile caps are terrible. I keep hitting ctrl by accident
Offline mkawa
« Reply #13 on: Wed, 24 September 2014, 14:57:34 »
top of case is rubberized, bottom is not
Offline salcan
« Reply #14 on: Wed, 24 September 2014, 15:54:01 »
Does anyone has a list of recommended keycaps for this, with all the compatible modifiers? BSP, GMK, and Imsto are all safe bets it seems? What else?
Interesting to hear everyone's thoughts on the 660C. I quite like the switch feel on the PBT model. It's an interesting take on Topre - not the best, but not at all bad IMO.
Offline Flyersfan1
  • Hi!
« Reply #15 on: Wed, 24 September 2014, 16:11:20 »
All of those would work with the exception of BSP.  They unfortunately do not have some of the molds used with most mass produced keyboards, and do not even make spacebars.  If you're looking for another good PBT alternative, you could check out the PBT sets that widebasket sells on eBay, they are very nice quality for the price.
Quote from: Photekq
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #16 on: Sat, 27 September 2014, 21:54:28 »
Maybe this gives SP a chance to shine here with their products.  Interesting to see of any of their DCS, DSA or even the God-like SA profiles will work perfectly with the current Novatouch ?
Offline mkawa
« Reply #17 on: Sun, 28 September 2014, 07:01:06 »
i'd actually really like to try a set of nuclear DSA on the board when it's produced. i've never used DSA before for an extended period of time. i don't think there will be an issue with fitment.
Offline mkawa
« Reply #18 on: Sun, 28 September 2014, 07:03:05 »
as for the novatouch vs the 10ae, the 10ae is still my favorite because, frankly, 55g uniform topre is the best, period, no question. i am highly impressed with the novatouch though. it is extremely solid, oozes of high quality, fantastic construction, good design, and has its own unique and solid switch feel. i just happen to like 55g more than 45g. imo if the novatouch came in 55g, it would definitely give my 10ae a run for its money.
Offline mkawa
« Reply #19 on: Sun, 28 September 2014, 07:03:17 »
and yes, i'm still going to buy a novatouch.
« Reply #20 on: Sun, 28 September 2014, 08:41:32 »
Nuclear is SA not DSA, unless another buy is coming.....
Offline HipsterPunks
  • Gangnamember
« Reply #21 on: Sun, 28 September 2014, 08:42:38 »
is it sad that i completely passed on this board because of the lack of v2 brobot support?
sell ass and eat out
Offline mkawa
« Reply #22 on: Sun, 28 September 2014, 09:40:07 »
yah, it's really worth a try, imo. just make a KBK that will fit on it ;)
and whoops on the nuclear green SA. i'm still not really sure what kind of cap will mesh best with this board, and i don't have a lot of caps sitting around to try. i suspect that the tour of the board (which will come with sample caps) be much better for figuring out the answer to this question. then, once everyone else agrees, i'll buy a set of that kind for the board i purchase after the review period is over ;)
Offline Hypersphere
« Reply #23 on: Sun, 28 September 2014, 09:40:09 »
The RF 87ub 55g has become my favorite board. I've replaced the black alpha, number, and arrow keycaps with blue ones, leaving all the others black, including the spacebar. It's sort of an inverse anniversary edition look, and I really like it.
Yesterday, I improved the sound and feel of a Kul ES-87 mx clear by putting Imsto dye-sub thick PBT caps on it equipped with 40A-L O-rings.
I put the stock thin ABS caps from the Kul on my CM Novatouch, and to my surprise, this improved my perception of the sound and feel of the Novatouch. In addition, I noticed an interesting thing: the Kul keycaps snapped into place rather than sliding into a friction fit with the stems. The Imso caps were far too loose on the Novatouch.
Overall, I still favor my RF 87ub 55g, HHKB Pro 2, and IBM XT keyboards over all the others. Nevertheless, the Kul ES-87 and CM Novatouch are close contenders, and I will keep them in my keyboard rotation.
Offline mkawa
« Reply #24 on: Sun, 28 September 2014, 10:50:01 »
with the light actuation, i'm not sure that a big thick cap will be the best for this board. hence my thinking that maybe a DSA set would be a really good fit.
Offline Latin00032
« Reply #25 on: Sun, 28 September 2014, 11:15:35 »
I want too hear an opinion on how the novatouch feels with 55g domes. Has anyone done this, yet?
Most if the reviews I've read so far show allot of people who prefer the rf 55g over the novatouch mostly because of the dome type.
I'd want to get an idea on how much different peoples opinions of the board would be if the domes on the novatouch were 55g.
I modded my 660c with 55g domes. There was a good difference. The only problem was I had one of the newer fc660c boards that had heavier domes. This made the swapping differences seem less notable. There was a difference but not as much.
I'm actually almost considering putting the regular 45g domes back into the fc660c.
Offline mkawa
« Reply #26 on: Thu, 02 October 2014, 19:58:03 »
modding my personal novatouch to 55g might be something i try, but not something i'll be doing to the tour sample. my feeling is that it would feel pretty similar to a 55g rf. with cherry profile caps that might be really really nice.
anyway, they finally set me up with a proper keyboard tray, and i ripped the horrible armrests off my chair, so i can actually type at work without my wrists going numb. this actually made a huge difference in how i use the board, as my actuation force is a bit lighter with the board at a proper negative angle and placed around waist-height.
dorkvader grabbed the second review sample and will be turning in a review, trying some POM caps on it, then passing it onto cptbadass of the keepers, who will assemble the first full tour kit and be turning in a review as well. dv mentioned that the stabilizers have been getting a lot of guff. we compared the stabs on the nova to the ones on my 10ae and while the 10ae is marginally more stable on the long right shift and the return key, the spacebar is very solid on both, and personally i think the difference is as much in the dome weight and very minor tolerances in the plastic than something inherent to the stabilizer design.
one reason i'm doing a longer term review though is that i am _BRUTAL_ to keyboards. if there is give in a design that is a fundamental problem, my banging on the board is highly likely to find it. cptbadass remarked that my well used 10ae was the first topre board he'd ever tried that rattled. one of the reasons i started playing around with building up new BS boards from scratch with bolts was because i cracked my first SSK barrel plate into 3 pieces in a month.
so yah, more updates as i get angrier at work.
Offline Elrick
  • Hype Master
« Reply #27 on: Thu, 02 October 2014, 23:30:40 »
Yeah, that's how you need to treat them with absolute hostility  8) .  No pulling back the anger, let it all out with vigour and contempt plus rub in a little audacity and a tiny sprinkle of vilification.  Stir in slowly and serve it luke warm with just a hint of bollocking.
If the Novatouch can survive all that then you're onto a winner.
Offline Hypersphere
« Reply #28 on: Fri, 03 October 2014, 08:52:33 »
It is fun being able to modulate the appearance, sound, and feel of the Novatouch by changing the keycaps and experimenting with various types of O-rings.
I've decided I really don't like mx clears, and so I have transferred the Kul keycaps from the Novatouch back to the Kul so that I can put the Kul up for sale. I put another set of dye-sub thick PBT caps on the Novatouch. These PBT caps are from geek_feng, and they fit better than the Imsto set did. The Novatouch looks, sounds, and feels great with these caps and no O-rings.
My only remaining quibble with the Novatouch is the Fn key. The Kul has a handy DIP switch setting for changing Fn to Menu, which makes it possible to use remapping software to configure Fn to my liking. The hardwired Fn key on the Novatouch cannot be readily reprogrammed. Therefore, I have remapped Right Control as Fn, but this leaves me with a useless Fn key on the board. If CM does not want to add DIP switches, perhaps they would consider leaving out the Fn key and replacing it with Menu, which would be reprogrammed easily -- this is what I have done with my RF 87ub 55g board.
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #29 on: Fri, 03 October 2014, 09:25:26 »
Thanks for the review.  I was also anticipating this keyboard, but after Key Con West, I am not going to buy one.  Here is why...
My daily drivers are a Model M and a Leopold TKL with Browns.  I have no Topre keyboards, and I dislike Cherry Clears.  I also have CM Storm keyboard in multiple flavors, including a 104 with MX Greens I use as my #2 keyboard at home.  (There is my bias exposed.)
On the table at Key Con West was the Novatouch, a 55g Realforce, a 660C, and the new Realforce 104UG "High-Profile" keyboard.  The latter has uniform 45g keys and very sculptured, high-profile PBT keycaps.  So of the four keyboards on offer, I was another person who disliked the 660C, and the 55g Realforce felt too hard -- like MX Clears, perhaps.  I did like the Novatouch and the Realforce 104UG. And I like both 104 and TKL keyboards, so the two are equivalent in my use.  (I have plenty of GH36 keypads...)
But what are the relative costs?
  Realforce 104UG with sculptured, high-profile PBT keycaps:  $240 at EK.
  Novatouch plus a Base Set of Nuclear Data Green keycaps:  $200 + $69 = $269.
So, except for the opportunity for future keycap changes, that $269 buys me a "Hybrid Capacitive Switch" keyboard from a vendor with a mixed quality history.   For less money I can get a genuine Realforce with honestly, some of the best keycaps I have ever touched.  We'll see about thick ABS SA, but the 104UG has throwback PBT keycaps that are much better (to my fingers) than either Imsto thick PBT, the Model M, or any keyset I have ever bought from SP.
Again, I liked the Novatouch.  But I didn't care for the throwaway keycaps it has.  As you might imagine, I will have no shortage of Nuclear Data Green keycaps shortly, so that wasn't really an issue.  But I truly loved the 104UG's sculptured keycaps, and so, for my money the Novatouch is over-priced for the value it offers.
Just my $.02.  Thanks for the review!
 - Ron | samwisekoi
Offline mkawa
« Reply #30 on: Sun, 05 October 2014, 20:22:21 »
worth pointing out that i don't know of any plans to do a 104 key novatouch. there's a tiny bit of apples and oranges on that one.
anyway, i'm starting to really dig the possibility of putting 55g domes on a novatouch with cherry caps. note to self: find a dead 55g topre board!
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #31 on: Mon, 06 October 2014, 10:26:06 »
Does it work the other direction? Can you put Novatouch sliders on a Topre board?
 - Ron | samwisekoi
Sig auto-typed by my GH36 LH keypad.
Offline Flyersfan1
  • Hi!
« Reply #32 on: Mon, 06 October 2014, 10:33:22 »
 - Ron | samwisekoi
You sure can! TJ has already transplanted the stems from the novatouch into his HHKB, and the stems from the HHKB into a novatouch.  The only problem being the stabilizer spacing between the two is slightly different, so it will still be tough finding an aftermarket spacebar.  The stabilizers are also interchangeable.
Quote from: Photekq
Offline CM-Rajiv
  • CM Storm Rep
  • * Commercial Vendor
« Reply #33 on: Wed, 08 October 2014, 13:52:08 »
;) No problem guys.
Cooler Master USA - CM Storm Marketing Team - [CM Storm Trigger CherryMX Green Switch]
Offline mkawa
« Reply #34 on: Fri, 17 October 2014, 04:17:43 »
sigh.. :(
my time with the demo novatouch may have to come to an end soon. frankly, it's been an excellent keyboard; i'm still going to buy one (exactly as i said at the beginning of this review). i'm really jazzed to have a proper keyboard at work that doesn't make a crapton of noise, and i'm glad i'm not paying for keycaps that i'm just going to end up tossing. the quality of this board is, frankly, excellent. it is the best of the non-realforce topres that i've tried, and frankly, except for the 55g vs 45g thing, i have no opinion either way on the 10ae vs the novatouch. the 10ae is 55g, which i like a bit better, and the novatouch is 45g topre. both feel like topre boards are supposed to feel, except that i had to import my 10ae from korea at an exceptionally high price with a long lead time, and i can walk into a store (ok, order from newegg, but you get the idea) a novatouch and have a high quality topre board in a day or two.
of course, you don't have to take my word on it, and i'm not nearly as finicky about certain things as you guys are, but not many keyboards become "keepers" for me, and this one is.
i'll post a few more thoughts as i wrap up and pass on the board to cptbadass for the tour, but that's my story and i'm sticking to it.
Offline dante
« Reply #35 on: Fri, 17 October 2014, 14:04:42 »
I'm not sure what you mean by apples and oranges - but Coolermaster should really consider doing a 104 Novatouch.
Here's why:
1. My requests to Seasonic for a 55g Type Heaven have fallen on deaf ears.
2. Brian @ EK says that a 104 55g is out of the question.  As far as I know Leopold of Korea no longer stocks the 104UBK 55g Korean version.
3. EK hasn't sold a fullsize (103UB 55g) 55g Topre in several years (2011?)
If Coolermaster can't come out with a fullsize can they at least consider selling the 55g domes separately?  I prefer this to purchasing two 55g 87U's.
Just because Coolermaster is a gaming company doesn't mean some of us don't use their keyboards for heavy data entry.
Offline osi
« Reply #36 on: Fri, 17 October 2014, 14:38:18 »
I enjoyed reading this. Interested to hear your points on what made the novatouch a keeper. :)
Offline _PixelNinja
  • C=Q/V=ε(A/t)
« Reply #37 on: Sat, 18 October 2014, 20:08:19 »
You would have to take that up to Topre, not Cooler Master.
Offline mkawa
« Reply #38 on: Sun, 19 October 2014, 07:26:30 »
oh man. dorkvader and i were going over the novatouch with some acetal/POM cherry profile keycaps on it (felt good, definitely better than OEM), and then he put a signature plastics' SA profile key from ctrlalt on it. HOLY CRAP. it feels amazing. if you have a novatouch already, buy a set and try it. TOTAL transformation of the board. the tactile point is incredibly well defined. the entire travel is 100% haptic. the weight is perfect. i am blown away, and i only tried _ONE KEY_
Offline BlackWidowMan777
« Reply #39 on: Sun, 19 October 2014, 13:03:35 »
I really enjoyed this review. It was like a bob the clack story but in a keyboard form. I too am attuned to the art of guesstimating actuation weights but I'm quite interested to know the precise cherry mx red board it feels closest to which enabled you to pinpoint the novatouch's keyweighting as bang-on evenly-distributed '45 g' as stated on the box.
Also how closely did the keycaps seem to be oem profile; and finally how dark is the box or fine is the print that made you have to use a gigantic torch. Was it a mandingo maglite?
Offline Elrick
  • Hype Master
« Reply #40 on: Mon, 20 October 2014, 00:31:43 »
Geez, did you know these keyboards are finally coming to Convict Town, go figure.  Based upon your review alone I'll be getting one to try it out, now I have to choose which key-sets to use on it.
Nice to see the Novatouch liking different key-sets.  I hope this doesn't mean the end of Cherry Keyboard love here on Geekhack ?  8) .
Offline dante
« Reply #41 on: Mon, 20 October 2014, 13:12:08 »
Any loose keys with the SA profile?
Offline mkawa
« Reply #42 on: Mon, 27 October 2014, 21:39:28 »
it felt bang on like my ducky yotd purple led/red switch from ye long ago. even longer ago, i had a pcb mount vortex poker from the first production batch that passed through all the different switch and spring combinations from reds to clear stems on grey springs. it didn't feel like any of those. it definitely felt like the plate mounted reds from the yotd.
the keycaps are OEM profile as far as i can tell. if they aren't, they're indistinguishable from OEM to me.
i seriously had to like squeeze up to a desk lamp with the box to read the text. there is some pretty serious black on black crow in a coal mine insetting going on on that thing. that's not the important thing about the box though. the magnets are. i could seriously play with that magnetic flap for like an hour.
i didn't get to try a whole set of SA keys on the board, but between the cherry POM set and the SP SAs, the cruciforms on the SA keys were looser. they weren't wiggly loose, but they weren't as tight as the OEM keys or the (original) cherries. this is all in the tolerances though. there is a bit of skewing due to the age of the tooling (SP's tooling is very old, while CM's stem tooling is very new), but any tightness or looseness felt when mounting the keycaps goes away pretty quickly as you type on the keyboard. the good news was that no key we tried felt so tight that we felt like we were going to break something pulling it off (something something vortex thin abs w/ cherry stabilizers :|)
Offline mkawa
« Reply #43 on: Tue, 28 October 2014, 18:27:08 »
so, i think i've pretty much reached a conclusion on this review. as i said at the beginning of the review, i'm going to buy one. now that i've used one for a while, i'm going to buy a set of SA keys to put on it. then, i'm going to use it, because i find it to be very good.
in fact, i find it to be so good that i'm kind of resisting sending it on to cptbadass for tour prep because i'm going to miss this particular board so much :(
#firstworldkeyboardproblems
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #44 on: Tue, 28 October 2014, 18:36:48 »
GMK is pretty magical on it, too.  I'm a fc660c fan because of gmk and novatouch sliders now.
It may be because I don't have a usable hhkb to compare with right now, too.
Offline frosty
  • jukebox hero
« Reply #45 on: Tue, 28 October 2014, 23:39:03 »
Got a change to test out a Novatouch with think cherry dyesubs on it (albeit the bottom row is funky). I have to say this is a different feeling all together...
« Reply #46 on: Wed, 29 October 2014, 18:27:20 »
+1  I haven't used another board since I put GMK on the Novatouch (used to swap every day or two).  I'm questioning everything.
Offline exitfire401
  • The Force is Re/\l
« Reply #47 on: Wed, 29 October 2014, 18:41:07 »
It almost came home with me.
« Reply #48 on: Wed, 29 October 2014, 18:47:52 »
Actually GMK is pretty magical on anything!
Offline mkawa
« Reply #49 on: Tue, 04 November 2014, 06:58:40 »
screw it. i'm not giving up _MY_ novatouch. i'll buy everyone a new novatouch off the shelf for the tour. DON'T TOUCH MY NOVA... touch
