Author Topic: Help me find a low profile keycap set  (Read 5051 times)
Offline rsantos97
« on: Thu, 25 September 2014, 09:21:55 »
I just ordered a Novatouch and would like to replace the keycaps with some thick low profile keycaps, like ones used in many of the scissor switch keyboards.  Can you guys help me find the right set?  Right now I am using an RF 97u at work and I do not like the high profile and the extra spacing of the keys.
Re: Help me find a low profile keycap set
« Reply #1 on: Thu, 25 September 2014, 09:23:28 »
I think that DSA or Devlin caps would work well for you. Check them out :).
Offline rsantos97
« Reply #2 on: Thu, 25 September 2014, 09:47:04 »
Thanks I will check them out.
Offline limitz
  • "the old gods stir and will not let me sleep..."
« Reply #3 on: Thu, 25 September 2014, 11:30:27 »
In terms of height, DSA is the lowest profile out of DCS, OEM, SA, and GMK (Cherry).
Mmm... machined aluminum
Offline davkol
  •  Post Editing Timeout
« Reply #4 on: Sun, 28 September 2014, 14:10:30 »
DSA is a bit higher than home-row Cherry or DCS. In fact, home-row DCS are probably the lowest widely available keycaps.
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #5 on: Mon, 29 September 2014, 04:50:44 »
DSA caps are great. I have the Granite set on my V60 Mini and I love it. They have done a couple of rounds of the set so you may be lucky enough to find one in the classifieds
Offline frosty
  • jukebox hero
« Reply #6 on: Mon, 29 September 2014, 07:12:36 »
Is the cherry or DCS profile shorter in terms of height?
Offline davkol
« Reply #7 on: Mon, 29 September 2014, 09:06:17 »
DCS home row sits a tiny bit lower and the other rows use pretty steep angles.
Offline Zeal
    • Zeal Generation Inc.
« Reply #8 on: Mon, 29 September 2014, 10:27:44 »
There's M8 (low) profile keycaps that are lower than and slightly thicker than DSA, but they're only available in 1u, 1.5u and 2u (Ergodox anyone? [oh god, I sound like tp4]).
Front to back: M8 low profile (only supports PCB mount stabs, bottoms out on housing), M8, SP DSA
Left to right: SP DSA, M8, M8 Low profile
2u blank M8 sitting w/ rest of granite
Cherry M8 DS, SP DS DSA, Cherry M8 Blank
Has a smoother and "scoop-ier" face
